A/C compressor failure
Old Oct 13, 2015
MauricioParilli's Avatar
MauricioParilli is an unknown quantity at this point
Exclamation A/C compressor failure
Hi! I've been having trouble with my 1999 civic's A/C lately and I was hoping someone could help me with it.
Symptoms:
High preassure too high on minimun (200 psi)
High preassure rises up to 400 psi when accelerating
High preassure gauge vibrates
Compressor sounds loudly
Activates and deactivates repeatedly
Takes a lot of power out of the car
Doesn't cool air as it should
I already have:
Changed dryer and expansion valve (2 months ago)
Replaced condenser fan motor
Cleaned the entire system
Cleaned condenser and evaporator
Questions:
Is it the compressor that's failing or could it be something else?
If I replace the compressor, should I also change the valve and dryer, even if they're only a couple months old?
What else should I do to replace the compressor?
Old Oct 13, 2015
Re: A/C compressor failure
System is seriously Overcharged or there is a blockage?
What is the low side pressure doing at idle
and what is the low side pressure doing when the RPM is raised and high side goes off the chart?
Old Oct 13, 2015
System is not overcharged. It is actually undercharged, only has 400 g of R-134a because i didn't want to charge it completely. I don't know if is is blocked somewhere, but I changed expansion valve and dryer checking if they were blocked and it didn't solve the problem.
At idle, the low pressure side is at 40 psi, and when I rev up the engine it goes down slightly, around 20 psi. It used to go lower, almost to 0, before I changed the valve and dryer.
Old Oct 13, 2015
Too much oil in the system can mimic an overcharge condition, as it takes up valuable space inside the system and can't be compressed in liquid form.
Condenser fan is operating when the AC is running?
You say you cleaned the condenser and other parts.....did you check for good flow volume through the condenser pipes?
Has it ever had a compressor failure?
Does this compressor sound noisy?
If the system is truly undercharged then there almost has to be a blockage somewhere after the high side service port.
(A failing compressor will often send debris into the condenser, which becomes a restriction. If your high side service valve is between the compressor and condenser, you would be able to see extreme pressure on the gauge.)
Feel the system while it is running, figure out where the high side of the system makes a big temperature change.
If there is a restriction, it should also act like a second orifice or expansion valve and should cause a temperature change.
Old Oct 15, 2015
Well, I hadn't paid much attention to the condenser fan since it had been replaced recently. Turns out that now it isn't running, and I'm guessing it never worked very well since it is not an original part, and that's why it didn't solve my problem. Now that it does't work it got way worse. So can the failure I describe be caused by the malfunctioning of the fan? I took it to a A/C shop, they threw water through the compressor and the pressures instatly dropped to normal levels, as if the heat exchange couldn't be done on its own with regular air, so I'm guessing condenser fan is a good guess.
On the other hand, I don't know if there's excess of oil. Is there a way to measure that without bringing down the compressor?
About an obstuction, I can't check what you say about the change in temperature since I can't turn the A/C now.
Old Oct 15, 2015
Absolutely, that's why it was up near the top of my guesses LOL.
Fix that and recharge with the correct amount of freon (if necessary) and see if it cools correctly again.
If it cools ok after that then I wouldn't worry about the oil.
Old Oct 15, 2015
As you said, seems like the fan was the problem. I replaced it and works great, considering it has less gas than it should, although I didn't get the chance to check it with the manometers. I'll do that and if everything goes well, I'll add the neccesary amount of gas.
Thanks a lot!
JAMorganIII
23
Jul 4, 2015 11:52 AM
Jro773
Jun 9, 2015 06:38 PM
jordan1794
Jun 8, 2015 08:37 PM
lapchern
Jun 4, 2015 04:35 PM
werdnahall
May 17, 2015 11:37 AM
