Maintenence Concerns For 248k miles
Old Sep 3, 2013
Roche's Avatar
Roche is an unknown quantity at this point
I'm buying a one elderly owner 2000 DX sedan with very high miles. It was well maintained. Timing belt every 100k, so it's not due for 50k miles or so.
The only thing I plan on doing is switching the gauge cluster to a CRV one, so I gain a clean looking tach and amber color.
My questions are:
With 248000 miles, should I be changing the oil every 3500 miles? I've read Honda recommends 10000 mile OCI which seems way too high to me. Also, should I be replacing the plugs, wires, belts, etc sooner?
Finally, should I use top notch plugs and full synthetic oil? I plan on keeping it 5-30 like it says, unless heavier is better for so many miles. Plus it gets pretty cold in winter.
I've never owned a car with so many miles, thanks for the help!!
Old Sep 3, 2013
Stock 99's Avatar
Re: Maintenence Concerns For 248k miles
My questions are:
Probably a D16Y7 engine - I have one. They have a good track record for going high miles. I know of quite a few high mileage ones around me and they all sound good, look good and from what I understand don't burn/leak. Users manual was 3500 miles for oil change I'd stick to that with a conventional oil or blend if it's cheap. I don't use full synthetic because it's too expensive to change at 3500 and I'm not comfortable going longer on an oil change. I use the standard 5w30 and have no leaking/burning issues but on any car that's unknown to you keep an eye on the oil for awhile. You can test plug wires with a multimeter if you want to check them. In fact you should at least inspect everything you rattled off there. First year I had my car I took it entirely apart. Inspected steering, suspension, tires (constantly), brake lines, components, ALL fluids (constantly once a week or more). I have done all the interval maintenance on mine for the past 3 years and it still runs like a new car. I have the same argument for the spark plugs as syth oil. I like to change the plugs in my car once and a while and it's super simple on this car.
I personally wouldn't worry about the mileage on that car at all if it seems to be in good operating condition.
The first thing I did on mine was a cluster swap as well and it's laughably easy.
Old Sep 3, 2013
Roche's Avatar
Thanks! All that makes me feel better about it.
I'll just pick up Castrol High Mileage and NGK Vpower plugs, seems to be favorable for these engines. Hopefully I don't get the wires confused with the gauge swap and there's a harness for the tach!
Old Sep 4, 2013
GolNat's Avatar
Prelude Owner
Always NGK for plugs. Castrol is what I use, good oil!!
I do prefer synthetic for the extra mileage protection, but that is me. 10K can easily be reached by todays oil standards, much better then they were back in the day.
Old Sep 4, 2013
Koch98EX's Avatar
Koch98EX is an unknown quantity at this point
Do you have pics of this swap Before/After? What year CRV do you get the cluster from?
Old Sep 4, 2013
Stock 99's Avatar
These are the best pic I have of mine. I just ordered it from my local junk yard but it's a civic cluster w/tach. Make note as well if the CRV redline is the same as what your driving. There's a FAQ just search 'cluster swap' you'll find info here....
pics are from my 'introduce yourself' thread
https://www.civicforums.com/forums/1...-15-years.html
Old Sep 4, 2013
Roche's Avatar
Unfortunately the guy decided he didn't want to trade. However I'm not giving up on getting a Civic!
mattdoc
Mar 14, 2017 12:10 PM
gearbox
Electrical DIY
72
Nov 27, 2015 08:13 PM
mrohitredd
May 28, 2015 10:03 AM
BootyDo
May 7, 2015 04:46 PM
bsmiley
Apr 27, 2015 01:27 PM
