High and fluctuating idle P0505
Old Aug 17, 2013
PaintYaCity's Avatar
PaintYaCity is an unknown quantity at this point
Im have idle problems again. Code p0505 - IAC valve... My thing is i just replaced the IAC valve with a brand new one less than 6 months ago. I checked the plug and it is secured well. I have a 00' with a jdm d15 with vtec head and 3 stage vtec. The car idles at 1000rmp and when i rev it the idle fluctuates between 1000 and 1500 before settling back down @ 1000>
The last time i had this problem it was the intake mani gasket, i just tore the motor down and did a head gasket and replaced all other upper gaskets so that shouldnt be it, any other ideas on what it could be and where to look? maybe wire harness somewhere or a vacuum leak in a hose?
[/IMG]
http://s653.photobucket.com/user/all..._0504.mp4.html
Old Aug 19, 2013
Fliptard's Avatar
Fliptard will become famous soon enoughFliptard will become famous soon enough
Re: High and fluctuating idle P0505
first off, there is only 1 ecu to run that motor correctly, a P2J I believe. there are a couple diff ones for different OBD2a and OBD2b's. I don't know a whole lot about them, but based off a quick search that is what I found.
Did you bleed out the coolant system properly.? that will also cause the IACV to make a fluctuate.
Old Aug 21, 2013
The car ran fine for over a year with the ECU in it so I don't think the wrong ECU is the problem.
The radiator is full and it ran fine after all the last work I did to it.
How can I bleed the system to make sure I don't have any air pockets?
I pulled the coolant hoses going to the intake and IAC Valve, checked them and they all appear to be fine.
Old Aug 22, 2013
Fliptard's Avatar
set the front of the car up in the air to help. Open cap, turn heater on and let the car run so the fan comes on a couple times, and add coolant as needed. I usually do mine for awhile just to make sure. another issue, that I had once, was the FICV under the Throttle Body was out of adjustment. which caused my car to idle really high and smoke a bit.
Rob02Civic
Sep 16, 2018 09:16 PM
Kaelin
Jun 19, 2015 04:19 PM
Bradel26
May 30, 2015 10:24 AM
vtechcivic
Apr 21, 2015 06:58 PM
1stcivic
Nov 18, 2001 09:17 PM
