Please help first civic.
Old May 18, 2013
TurboWhistle's Avatar
TurboWhistle is an unknown quantity at this point
I've always been a Honda Enthusiast. I've owned a mazda protege and have always wanted a civic. Im finally getting one. 1996 Honda Civic EX. The only thing is idk if its vtec. The valve cover doesn't say vtec. just Honda. And the mechanic who owns it says it is vtec. I'm not sure. I'm still getting it either way. And what type of EK is it? Thanks a lot guys.
Old May 19, 2013
Lordsin's Avatar
Lord Sin
Lordsin is an unknown quantity at this point
Re: Please help first civic.
Look at your vin it's the 678 letters to say (ej# or ek#). What does the engine block say?d16y?
Old May 19, 2013
Can't remember man I'll let you know later today with some pics. It's getting towed here due to no tag. Thanks a lot for letting me know though.
Old May 19, 2013
It's a d16y8
Old May 20, 2013
Lordsin's Avatar
Lord Sin
Y8 is vtec, but idk if he change the valve cover or head.
Old May 20, 2013
ishjay's Avatar
ishjay is an unknown quantity at this point
Check if there's a VTEC solenoid behind the head,
Old May 20, 2013
It's there. When I get tags on it Im going to try and hit vtec and listen for the crossover. From what I heard the ej8's come with vtec and the dx and lx versions don't. I'm still happy though.
Old May 20, 2013
ishjay's Avatar
You could hear it at first gear. Press the gas slightly. Should be around 3500 rpm thru 4500 rpm
Old May 21, 2013
I wish I could . But the cluster was swapped from an EG. So I don't have a tach. Idk what RPM I'm at lol. I'm thinking of getting a cheap autozone tach and mount it somewhere.
Old May 21, 2013
burgoyne's Avatar
burgoyne is an unknown quantity at this point
You could always switch the entire cluster out for a cluster with a tach? If you go that route, I always found the Si clusters to look awesome!
Or you could do what I did.
http://www.glowshiftdirect.com/96-00...e-cluster.aspx
I bought one of those, and mounted two gauges in it.
Old May 21, 2013
Lordsin's Avatar
Lord Sin
...... Why would he mount and eg one.....
Old May 21, 2013
Idk man. It was only 2100. Had coilovers, aftermarket wheels, exhaust (I hate it its so loud), a factory kit, d16y8 vtec, and had a ton of loose change inside. I just gotta do a bit of work on it.
Tedverseti
Sep 29, 2015 05:41 PM
brash99
Sep 29, 2015 08:42 AM
ttamrekab
Sep 28, 2015 01:22 AM
speedlever
Sep 24, 2015 07:18 PM
Brad Andrew
Sep 8, 2015 08:22 PM
