HELP!!! Having Issues With Cooling System In 2000 Si
Old Nov 28, 2012
mikeneamtu's Avatar
mikeneamtu is an unknown quantity at this point
Exclamation HELP!!! Having Issues With Cooling System In 2000 Si
So about a month ago I replaced the thermostat at a shop...my car started overheating slightly so I thought that was the issue...Now my fan does not turn on anymore and when I trickle charge it with the battery it works fine....so I went a got a fan switch and replaced that....still nothing.....also my rad does not hold coolant it all gets dumped back into the reservoir and every week or so i have to dump the reservoir back into the rad and bleed the system and top it off again....I have no coolant leaks anywhere because my driveway is spotless and also the bottom hose of the rad never gets hot (therefore no coolant flowing through)....only the top hose gets hot and unless it overheats a bit then the lower hose gets some coolant through it, but the fan never turns on.....
So my question is what could be causing this? Could the thermostat be faulty or installed improperly? Or could the rad be clogged somewhere and not allow flow of coolant properly?
If i could get some help with this I would appreciate it a lot.
Thanks
bravo79
Suspension
18
Feb 10, 2022 09:52 PM
What_It_Do
May 10, 2015 05:31 PM
hokiedad4
May 3, 2015 10:06 PM
bsmiley
Apr 27, 2015 01:27 PM
tylerginevan
Apr 27, 2015 12:29 PM
