98 civic idle problems
Old Jun 5, 2012
RudyG619's Avatar
RudyG619 is an unknown quantity at this point
Ok so I have a 98 civic ex vtec 1.6L automatic,the problem is when I start my car it idles at around 2000-2500 but once I put it in drive it goes down to around 500 to 1000 and when I stop at a light it goes down to around 200 or sometimes even less and the car will shake and sometimes shut off the only wayI can prevent it from turning off is by giving it a little gas..I cleaned the throttle body plate the other day but its still acting up.it will act normal sometimes and only idle around 1000 ..and also the car usually turns off on my first drive of the day and for the rest of the day it won't turn off but it will still idle very low at stops.it annoys the crap out of me and I would like to know if anybody has had these problems and how they fixed it??and if anybody just knows anything please let me know.??.
Old Jun 5, 2012
RudyG619's Avatar
Re: 98 civic idle problems
Also I do warm up my car before I drive it..i let it reach the about a quarter..sorry I dont know how hot that is..
Old Jun 11, 2012
98civic47's Avatar
98civic47 is an unknown quantity at this point
try cleaning out your iacv to see if that helps if you dont know where it is its in the back of the motor kind of in the middle on top.... look up a pic and check it out... if you know what you are looking for you cant miss it
Old Jun 12, 2012
RudyG619's Avatar
Yeah I've been wanting to try that..I put some fuel injector cleaner about two days ago and it hasn't turned off on me at stops but it still idles real low..thanks for the reply tho and advice
Old Jun 17, 2012
98civic47's Avatar
if you use injector cleaner i would recomend using lucas... it really works great use it myself
Old Jun 17, 2012
michael3n's Avatar
michael3n is an unknown quantity at this point
You may need to try an idle relearn. Pop the hood open and open the fuse box under the hood. Remove the backup fuse about fifteen seconds then put it back (you'll lose radio stations). With radio/lights/air/everything else off, turn on the car and let it idle for ten minutes. Turn it off then see if it still does this.
Old Jun 18, 2012
RudyG619's Avatar
Alright imma try that fuse trick,and when you say let it idle you mean just leave it on right?I've been wanting to clean iacv but dammn I look at it and it looks like a lot and I don't wanna mess something up..
Old Jun 18, 2012
palsana's Avatar
palsana is an unknown quantity at this point
Ive had a 03 civic ex 4dr and i had IACV cleaned up, however i did not do the idle re-learn. i suppose i need to do that..its been over 2 mos now since my iacv cleaning.
is doing the idle re-learn now a good thing. or do one more clean & then do idle re-learn.
Old Jun 18, 2012
michael3n's Avatar
The idle relearn is because the system 'learned' how to run with the conditions it used to have. The computer is still making the same adjustments it used to, despite the system having changed a bit. When things change, this can cause it to adjust incorrectly and idle high or low.
And yes, I do mean just leave it on. Do not press on the gas or breaks or listen to the radio or anything.
ADDITION: Do the idle relearn after a drive sometime. The engine should already be at normal temperature and turned off before you pull the fuse.
Old Jun 18, 2012
RudyG619's Avatar
The car has stopped on me twice since I put the fuel injector cleaner it was runnin good the first week of fuel injector cleaning but then like I said it stopped twice on me and right now I took it for a drive and it was idle reallly really low and my car would shake a little..but right now I'm doing idle relearn so well see how that works..thanks again for advice guys..if this doesn't work ill clean iacv fersure...
Old Jun 18, 2012
palsana's Avatar
my car simply shakes/feels weight on engine only when my A.c is on?
try cleaning up pressure regulator it will get you better idle!!!!!..not exactly solve problem, but thats what worked on mine. I however, also did a fuel filter strainer change and throttle body cleanup. Not to forget idle Re-learn after it.
Old Jun 22, 2012
RudyG619's Avatar
I did the idle relearn it didn't help so much,my car still stops on me it fluctuates from 0 to 1 rpm I'm gonna clean iacv tommorow if there's any tips you guys could give me that'll be greatly appreciated like what I'm going to have to take apart for the job to be easier..and also a picture of iacv would be cool too but I'm pretty sure I know where its at..it should be like connected to throttle body around there..right? Lol
Old Jun 23, 2012
RudyG619's Avatar
Alright so today I cleaned the iacv in my car and damn it was dirty real dirty but anyways I started the car after it felt like it was struggling a little at first but it turned on good but it was idling at 2000 then I'm not sure what my dad did in the hood but it started idling lower at about 1000 then I drove it to the store and it turned off on me cause it started idling real low,so then I got home and did idle relearn and its acting normal finally it stays at 1000 almost all the time it goes down a tiny bit sometimes but not to much..
Old Jun 24, 2012
palsana's Avatar
Take it for a spin of about 100+ mi and you will see all getting normal. In the first few days of cleaning iacv it did very little to change anything, however, putting on some miles made a huge difference.
Old Jun 24, 2012
RudyG619's Avatar
Yeah I took it for a pretty long drive yesterday about 50 miles there and back it was running good and today I drove it in the morning the idle stays at 1 it rarely moves at stop signs or lights..it finally works perfect thanks everybody for the advice and tips really appreciate it !
TXcivic2001ex
Air Conditioning
23
Jul 20, 2020 07:27 AM
beneditti
Jan 15, 2016 12:31 PM
Civicchicky87
Idle Issues
Apr 22, 2015 07:16 PM
vtechcivic
Apr 21, 2015 06:58 PM
streetglower123
Apr 12, 2015 10:56 AM
