JDM D16 Wrong Crank?!
Old Mar 23, 2012
ugadawg187's Avatar
ugadawg187 is an unknown quantity at this point
I have a 97 civic ex with that had a D16Y8 & bought a JDM D16Y but after replacing the crank seals found out the crank was bigger so the gear from my original motor wouldnt fit it. My crank gear bolt was a 17mm & the JDM motor was a 19mm. Are there any ways to solve the problem so the crank sensor will work? I was told they dont run crank sensors in japan so it didnt matter there.
Old Mar 24, 2012
Zeferint's Avatar
Autocross Padawan
Zeferint is a glorious beacon of lightZeferint is a glorious beacon of lightZeferint is a glorious beacon of lightZeferint is a glorious beacon of lightZeferint is a glorious beacon of lightZeferint is a glorious beacon of lightZeferint is a glorious beacon of light
Re: JDM D16 Wrong Crank?!
There's a couple things you can do:
Buy a JDM ECU. They don't read the crank sensor like the USDM ones do so if you swap one in then you're all set.
Option two is to just use an obd2a jumper to obd1 and don't plug the crank sensor in at all. There's no pin for the sensor in the jumper harness, so your USDM ECU won't go "WTF" when you try to start the car.
Option three is to just buy USDM parts
Old Mar 24, 2012
ugadawg187's Avatar
Thanks for the info I knew sometimes it could be jumped from the distributor but hadnt thought about replacing the ECU. Will try the jumper first.
Old Mar 24, 2012
Zeferint's Avatar
Autocross Padawan
No problem man keep us posted!
Old Apr 2, 2012
ugadawg187's Avatar
Got motor in with a jumper from the distributor and so far runs good alot more power compared to the original motor. Thanks for the help.
Old Nov 4, 2012
ugadawg187's Avatar
So ive been researching this motor & it has a y8 vtec head casting with a y7 non vtec valve train. The crank is a 19mm like the d17's but dont know if its from a d17. Having oil pressure problems now & the car only ran right for two weeks after i had the motor installed. So frustrated and dont know what to do. I feel like this motor has been mismatched.
Civic65
Jul 19, 2015 10:13 AM
LorenzoC0395
Jul 14, 2015 08:46 PM
1khilari
Jul 9, 2015 08:12 PM
Pwelsh
Engine start problems
Jul 9, 2015 04:15 PM
CivicsClass101
Jul 9, 2015 11:14 AM
