valve cover bolt nut broke idk
Old Jan 13, 2012
XI JuNiOr IX's Avatar
XI JuNiOr IX is an unknown quantity at this point
Angry valve cover bolt nut broke idk
where the bolt screws from the valve cover it broke and a pice fell where the oil drains down... civic d16y7 1997... am i screwed or can it be replaced help please
Old Jan 13, 2012
Gunner's Avatar
A true genius admits that he/she knows nothing.....CLOSED SAT/SUN
Gunner is a name known to allGunner is a name known to allGunner is a name known to allGunner is a name known to allGunner is a name known to allGunner is a name known to allGunner is a name known to allGunner is a name known to allGunner is a name known to all
Re: valve cover bolt nut broke idk
The bolt can be replace you are going to have to TAP it out...When you say a piece fell where the oil drains where exactly do you mean? internal of the motor???
Old Jan 13, 2012
04 Honda Civic's Avatar
You need to get that piece out. Drain your oil and see if its there. If not pour oil into the valve assembly area with your oil drain bolt out and pray it comes out.
Old Jan 13, 2012
Yes it went in the engine and the bolt didn't brake where it screws in.... Like when you put the valve cover and your puting the bolts the one on the bottom left corner broke and I pulled out the bolt it was fine but the inside was ducked
Old Jan 13, 2012
Post pictures it sounds like you cracked a piece on the head?
Old Jan 13, 2012
I got the piece out but now I still have the broken thing it has a number 1 on it and theres other ones that have numbers it starts where the belt is hooked with 1 then to all the way to 5.. Ends at the other side of the head... My pictures have to much pixels..
Old Jan 13, 2012
How did you manage to get the piece out?
Is it a piece on the Valve cover itself or the engine?
LionSpratt
Jan 29, 2017 11:07 PM
JohnnyBxo
16
May 9, 2015 05:53 PM
MN-02-CivicEx
28
May 2, 2015 09:11 PM
ALLMAN
Engine DIY
73
Jan 19, 2009 11:21 PM
bambuski
Dec 16, 2001 05:57 PM
