exhaust swap cel possible fix let me know what you think
Old Oct 18, 2011
jeremy2717's Avatar
jeremy2717 is an unknown quantity at this point
hi everyone im jeremy new here 96 lx 4dr 5sp. i had the usual cracked manifold so i went with ebay header back system $175 with all 6 pcs. i noticed the crack when my cel came on and i went to replace the primary o2. i accually didnt replace it what i did just to see if it would work was put my secondary in place of the primary witch took the primary code away and left me with only a secondary code. since my test pipe has the bung on the bottom to correctly fit i cant really put the o2 sensor there cuz its pointing to the ground so what i did was just got a sensor from the junk yard plug it into the harness cleared the code from ecu and just left it hang. i did tie it up with zip ties so it didnt bang around or drag. i have only put about 10 miles on it so far but the cel is staying off and im not getting any codes. am i doing any harm by running with it setup the way i have it now. and do you think the light will stay off. ill keep everyone posted on what happens with the cel i hope this works out ok i need emisions this month and am on a budget and really cant afford anything else right now let me know what you think im open to all opinions and everyones thoughts thanks jeremy
Old Oct 19, 2011
jeremy2717's Avatar
Re: exhaust swap cel possible fix let me know what you think
so noone has any input on this I see quite a few ppl read post no responses tho.
Default_Slayer
Electrical DIY
Dec 4, 2022 07:56 AM
juror
May 26, 2015 06:35 PM
rcolosi
Apr 29, 2015 07:48 PM
Fastfebur
Apr 26, 2015 11:57 PM
supercivic01
South
Nov 30, 2001 11:27 AM
