I need help. Someone please
Old Sep 2, 2011
jdmkid01's Avatar
jdmkid01 is an unknown quantity at this point
Exclamation I need help. Someone please
Hi guys. i have a 1998 honda civic dx and i thought of buying a 1999 honda civic ex guage cluster because the cluster i want has a rpm guage. My question is would it fit and work completely. Please help me.
Sincerly jdmkid01
Old Sep 2, 2011
Steven21's Avatar
Steven21 is an unknown quantity at this point
Re: I need help. Someone please
Yes it would fit and work fine the only problem is that the rpm gauge will not work because the dx did not come with it. Other than that it's direct plug and play you'll just have to have to run wiring to get rpms to show, which I know nothing about
Old Sep 2, 2011
jdmkid01's Avatar
Exclamation Re: I need help. Someone please
I need more sugjestions! Please someone help
Old Sep 2, 2011
i dont know about the actual fitting part, but almost every civic dx comes with the rpm wire already hooked up in the harness. so if the connectors plug in and the cluster fits in the spot, the rpm should work.
Old Sep 2, 2011
Zeferint's Avatar
Autocross Padawan
Zeferint is a glorious beacon of lightZeferint is a glorious beacon of lightZeferint is a glorious beacon of lightZeferint is a glorious beacon of lightZeferint is a glorious beacon of lightZeferint is a glorious beacon of lightZeferint is a glorious beacon of light
Incorrect. OBD2 vehicles come with what's called a Crank Position Sensor, located in the distributor. This communicates the current RPM of the crank to the ECU and is pre-wired via the engine wiring harness. Therefore, when you plug in a cluster that has a tachometer, it will be plug and play.
So my advice? Buy the cluster and pop it in. Just note that the mileage on the replacement cluster cannot be changed to your current mileage so you will have to note at what mileage the original cluster was changed.
Old Sep 2, 2011
Steven21's Avatar
Well I did not know that good to know though thanks for the save
Old Sep 2, 2011
jdmkid01's Avatar
Thank you, Are you 100% sure. I dont want to spend the money then have it not work. im buying it because i want the rpms. i could care less about the milage. I need to make sure ur 100% sure that if i plug it in the rpms will work also
Old Sep 2, 2011
Zeferint's Avatar
Autocross Padawan
I am 100% sure. The mileage is irrelevant but make sure you note the mileage on the old cluster so you know the actual miles when you go to sell it.
Old Sep 5, 2011
b00$t's Avatar
b00$t is an unknown quantity at this point
Plug it in and it'll work.
ken4444
Sep 30, 2015 07:37 PM
juicetayne
Sep 30, 2015 11:02 AM
frank_kleng
Sep 29, 2015 10:55 PM
Islesfan
Sep 29, 2015 03:42 AM
C-Hamm
Sep 28, 2015 10:31 PM
