2000 Front Bumper Cover Repair
Old Mar 19, 2011
Civictim's Avatar
Civictim is an unknown quantity at this point
Managed to hit a good sized dog on the freeway, and it cracked my bumper/ bumper cover. It looks fixable, but I've got to get it off first. Any one know how to do this? If not, does anyone know where I can get the info to take the bumper/cover off? Thanx.
Old Mar 19, 2011
asianboy781's Avatar
asianboy781 is a jewel in the roughasianboy781 is a jewel in the roughasianboy781 is a jewel in the roughasianboy781 is a jewel in the rough
Re: 2000 Front Bumper Cover Repair
if u wait till next friday
ima work on my bumper yes i have a crack from hitting a gaurd rail and a snow bank but new bumper is on the way next tuesday
i will be taken pics of taken off the bumper and putting it back on
Old Mar 19, 2011
lazlong's Avatar
It's like 4 plastic body pins on the top, a dozen on the bottom, and 4 screws in the wheel wells (2 on each side). You may have to remove some body pins from the inner fender too.
Old Mar 20, 2011
^ yup, what lazlong said.
that said, kudos for the creative and funny username you choose...
Old Jun 23, 2011
nicko's Avatar
nicko is an unknown quantity at this point
hope this one can help:
Removed the screws above the grille, about two or four screws, but first you have to open the hood to make it possible, this procedure is for front bumper, since most of rear bumpers doesn't have this screws.
Second, find the black plastic clips, it is actually snapped in another black plastic circle you should use a flat-head screw driver to snoop it, and keep it stays up.
Then, remove or cut the stem of the center circle, you might need to use a tool like a nipper here, this clip is non reusable because even if you didn't cut it, it may loosen while you are driving...
Lastly, if you ensure that all the clips and screws have been removed, pull the bumper cover from your car, place it in top of cotton based cloth like blanket or towel to avoid scratches on your bumper cover.
__________________________
PROTECT the ONE
THAT PROTECTS
YOU!!!
Old Jun 23, 2011
Zeferint's Avatar
Autocross Padawan
Zeferint is a glorious beacon of lightZeferint is a glorious beacon of lightZeferint is a glorious beacon of lightZeferint is a glorious beacon of lightZeferint is a glorious beacon of lightZeferint is a glorious beacon of lightZeferint is a glorious beacon of light
It might be different for 7th/6th gens, but the two screws in the wheel wells in 6th gens are actually to the skidplate; not the bumper. However, everything else Lazlong mentioned is correct. Look for phillips screws on the bottom underneath the car, black pop off pins on the top and two 10mm bolts in the inner fender..one on each side.
usajags84
15
Aug 19, 2015 03:12 AM
Thriftmaster
Vancouver
Apr 28, 2015 06:02 AM
SpeedRacer
Dec 6, 2001 09:40 AM
SQCivic
Nov 8, 2001 05:56 PM
