Fog light help??
Old Feb 17, 2011
tjb101084's Avatar
tjb101084 is an unknown quantity at this point
Fog light help??
I got a fog light kit from ebay and was woundering where on the drivers side under the hood can I connect to an ignition wire??
Old Feb 17, 2011
Newfiedan's Avatar
Newfiedan is a jewel in the roughNewfiedan is a jewel in the roughNewfiedan is a jewel in the rough
Re: Fog light help??
easiest place to do that is in the cabin of the car, at the factory fuse panel, either use a fusetap like a busmann bp/hhh and find a fuse thats hot when the key is on. Also make sure you run the wire through the firewall grommet so its properly protected, use a wire coat hanger to assist in this.
Old Feb 17, 2011
asianboy781's Avatar
asianboy781 is a jewel in the roughasianboy781 is a jewel in the roughasianboy781 is a jewel in the roughasianboy781 is a jewel in the rough
i found diy hope this help
well for the power source i use a relay and connect the constant voltage from my amp wire going from the passenger side.
that is just my idea and i use the turn on wire from the alarm parking light wire since it was already tap. so the first click my fog light and city light turns on then 2nd click is head light
heres the diy
http://www.hondacivicforum.com/forum...ad.php?t=61880
Exterior
Nov 28, 2025 05:23 PM
XXLUV2EXCELR8XX
Dec 16, 2001 04:56 PM
LuvMyCivic
Dec 12, 2001 10:02 PM
klam
Nov 19, 2001 05:46 AM
klam
Nov 16, 2001 03:36 PM
