Gauge Cluster problem, help
Old Feb 13, 2011
isaiddurazoo's Avatar
isaiddurazoo is an unknown quantity at this point
Ok so my heat gauge and fuel gauge are not working.
When I turn my left blinker on the rpm gauge goes up and down, changes absolutely nothing in the engine though, car drives just fine.
And its ONLY when I use the left blinker, this is how I got the car. Probably a wiring problem? Or do I need a new cluster?
Old Feb 13, 2011
Newfiedan's Avatar
Newfiedan is a jewel in the roughNewfiedan is a jewel in the roughNewfiedan is a jewel in the rough
Re: Gauge Cluster problem, help
Sounds like some hack wiring done to the car. I would start by checking out the wiring see if they tried to add any aftermarket lighting or remote start/alarm system and work from there. the heat gauge has a single wire on a sensor on the engine should be right behind the distributor check to see if that has gotten knocked off.
HiImBrandon
Jun 1, 2015 07:34 AM
Ma213802
May 18, 2015 07:01 AM
bahena08
Apr 11, 2015 05:09 PM
0100010
Jan 6, 2002 12:54 AM
guy
Dec 25, 2001 09:51 PM
