d16y8 head gaskets?
Old Jan 22, 2011
Just-in a Civic's Avatar
d16y8
Just-in a Civic is an unknown quantity at this point
d16y8 head gaskets?
how much does getting a head gasket repaired cost if i do it myself.
Old Jan 23, 2011
Newfiedan's Avatar
Newfiedan is a jewel in the roughNewfiedan is a jewel in the roughNewfiedan is a jewel in the rough
Re: d16y8 head gaskets?
if you are doing it yourself you could do it for around 200 bucks, remember to replace the head bolts and when taking the head off undo them in the opposite pattern as when you are torquing them up. Make 100% sure that you set the timing marks before you remove the timing belt and do not let it move when you take the head off. Get a haynes manual it details the whole process for you and make sure you check the head and block using a long straight edge and a feeler gauge to check for warpage if there is any get it machined at a machinist shop. I also like to clean the pistons and valves when its off using carb cleaner to get rid of any carbon buildup.
7thgensurvivor
38
Aug 29, 2015 11:50 AM
159
Jul 5, 2015 09:54 PM
jdawgzcivic
Jun 30, 2015 06:35 PM
Jun 2, 2015 11:54 AM
HondaHomer
May 14, 2015 12:24 PM
