Leak 99 civic dx
Old Jan 14, 2011
Steven21's Avatar
Steven21 is an unknown quantity at this point
Leak 99 civic dx
I went to refill my wiper fluid yesterday and found myself standing in oil or transmission fluids. i put the car up on the rack and didnt see any leaks but the bottom of the transmission was really wet but no sign of the leak. any ideas??
Old Jan 14, 2011
Re: Leak 99 civic dx
try to figure out which fluid it is first. if alot of fluid came out, its prolly a rear main seal.
Old Jan 14, 2011
Zeferint's Avatar
Autocross Padawan
Zeferint is a glorious beacon of lightZeferint is a glorious beacon of lightZeferint is a glorious beacon of lightZeferint is a glorious beacon of lightZeferint is a glorious beacon of lightZeferint is a glorious beacon of lightZeferint is a glorious beacon of light
Check the color of the fluid. Sometimes it can be hard to tell if it's oil or tranny fluid (depending on how often you change it). If the bottom of the transmission is wet, that's probably a good indication theres a tranny seal busted somewhere. Rear main seal is a possibility, but also check that there isn't anything leaking onto the transmission. Coolant is a possibility, and I think theres an oil return line that runs over the transmission in the engine bay, too. Just whatever you do, don't drive the car, lol.
Old Jan 16, 2011
Steven21's Avatar
ill try not to drive it lol but nothing id leaking on it. the top is dry and everything looks good on it until you see the bottom of the tranny. the color is rainbow on the ground so i was also wondering if it might be a gas leak?
Old Jan 16, 2011
asianboy781's Avatar
asianboy781 is a jewel in the roughasianboy781 is a jewel in the roughasianboy781 is a jewel in the roughasianboy781 is a jewel in the rough
rainbow would be oil
and gas evap fast
so i rule out its oil
Old Jan 16, 2011
did u check oil level
Old Jan 16, 2011
Steven21's Avatar
Oil and tranny levels are both fine
LionSpratt
Jan 29, 2017 11:07 PM
usajags84
May 10, 2015 08:11 AM
superstanko
Apr 28, 2015 04:38 AM
CascadiaBlue
Apr 18, 2015 09:13 AM
Lightman
Nov 10, 2001 06:44 PM
