Headers and Cams?
Old Dec 29, 2010
Nice not Rice's Avatar
Nice not Rice is an unknown quantity at this point
Headers and Cams?
I'm thinkin about getting new headers and cams for some more horsepower.. Anyone know any good ones? What is the best out there but not to much money.
Old Dec 29, 2010
MindBomber's Avatar
Live for the Twisties
Re: Headers and Cams?
Best one out there and not to much money are polar opposites.
Quality = Expensive.
Cheap = Garbage.
Old Dec 29, 2010
I use my car as a daily driver, What style should i use? A 4-2-1 or a 4-1.
Old Dec 29, 2010
MindBomber's Avatar
Are you modifying any other part of the exhaust?
Old Dec 30, 2010
I already have a Apexi exhaust
Old Dec 30, 2010
MindBomber's Avatar
Okay, while a 4-1 exhaust and a 4-2-1 exhaust each have certain advantages, but results hinge on your other components. A decent header through low end pipes for example will do nothing, the same with a cheap header through good pipes; a system is only as good as its weakest component.
A 4-1 exhaust is meant more for a race application, where it would be matched with a high duration cam and you would be spending the majority of in a specific power band. Overall it would give more hp, but thats all useless if you only hit 6500rpm during near red lines shifting. 4-1 works very well for a drag car.
A 4-2-1 exhaust does not give results as good as a 4-1, but its designed to handle a longer less aggressive cam profile and gives slightly added hp across the entire power band. 4-2-1 is more appropriate for auto-cross, road racing, DDing.
Old Dec 30, 2010
so a 4-2-1 is good for a daily driver?
Old Dec 30, 2010
4-2-1 will give you a little more torque on the lower/mid end, so would be recommendable.
4-1 is a high rev setup, which you don't use much on the streets.
And which engine you have in there? B-series or D-series?
Old Dec 30, 2010
D series
Old Dec 30, 2010
MindBomber's Avatar
4-2-1 for DD
4-1 for race car.
Old Dec 30, 2010
TRIZ's Avatar
I got a new box of springs and retainers for the d16 if your going to go through with this
UltraHDGames
Jun 8, 2016 05:16 PM
ricer_em2
May 11, 2016 08:09 PM
HondaGuy7
Feb 22, 2016 01:00 PM
jdh022764
18
Nov 3, 2015 06:44 AM
anubis62
Sep 27, 2015 12:56 AM
