Need help!!!!! Door problem! =x
Old Nov 25, 2010
droolander's Avatar
droolander is an unknown quantity at this point
i've just purchased me a 97 civic 4 door. the back driver side outside door wasn't working and my lame self got confused and thought "hey, it might be the child proof lock on." so i open the door from the inside and switched the child proof lock. Now assuming thought that was the problem, but really I REALLY got it all confused, i closed the door and now i completely cannot open the door from inside and out. Any kind of advice? Friend told me break the door panel from the inside, but i cannot see that happening. tried to switch the child proof from the inside by using a hanger, but it wont switch if the door is closed. PLEASE HELPPPP!!!!
Old Nov 26, 2010
lazlong's Avatar
Re: Need help!!!!! Door problem! =x
Sounds like the latch itself is bad. Maybe try taking the door apart from the inside. Start by taking off the window crank (if you have one), then remove the inner handle, then remove the grip cover and unscrew the screws in the base of the grip. The panel should have plastic pins that pop out towards you, then the whole panel slides up out of the window trough. Stumped at how to remove the latch itself without destroying it though.
numbersguy
Electrical DIY
Sep 15, 2018 11:24 PM
MamaBear2015
May 18, 2015 07:37 PM
MamaBear2015
May 3, 2015 02:17 PM
darwin-t
Apr 18, 2015 09:29 PM
Macko
Exterior
Nov 19, 2001 10:34 PM
