Is it possible to switch the Odometer with the RPMs?
I tried searching and couldn't find anything. sorry if I missed it. I was wondering if it's possible to switch the position of the odometer with the rpms as I would like the RPM gauge to be in the centre of the console. Anyone done this or know if it's possible?
Re: Is it possible to switch the Odometer with the RPMs?
Im guessing you mean the entire Speedometer part with the Tachometer (RPM's)? I have never seen one like that, you would need to get a whole new unit i'm guessing. Even when someone wants to do a gauge switch (the entire unit), the entire gauge cluster is taken out and replaced so I am going to go with its not possible to DIY. Usually people swap them out to get the one you have in the picture, for the ppl without a tachometer. But other than that I haven't seen a gauge cluster for civics with the tach in the center. Maybe someone will correct me if I'm wrong but im pretty sure you might be out of luck.
WKD DRGN
Jun 18, 2015 07:56 AM
Wild Cranker
May 19, 2015 06:10 PM
Ninetyatecivic
May 9, 2015 07:48 PM
dooner24
Apr 14, 2015 07:51 PM
