enhancing performance on 2000 si, cheap, whats first?
Old Nov 7, 2010
gbabbitt398's Avatar
gbabbitt398 is an unknown quantity at this point
Okay, so not a lot of money here but I would like to drop bit by bit into my 2000 civic si.. just wondering what you guys think is first.. I was thinking a cold air intake would be a good first choic, seems on how its remotly cheap, and from what I understand will give me a little pep on the throttle.. does this sound about right?
Also, if I were going to drop a chip in it would the cpu be a good first priorty for a cheap performance inhancer?
Thanks for the input!!
Old Nov 7, 2010
Mad Dog Tannen's Avatar
Re: enhancing performance on 2000 si, cheap, whats first?
Welcome to the furum.
I would get a Hondata ECU. The chip I have heard mixed reviews on, most say it's a bad investment. The Hondata ECU will give you the ability to tune it when you add news things to the engine in future, so I would say that a very good choice for a first mod. CAI does a little bit, but I would get Regular intake not a cold air one, only because it can suck up water.
Old Nov 7, 2010
Cold air intake can suck up water? Isn't there a way I can prevent that, like using a short arm pipe? Honestly I would prolly bui?ld thee pipe my self..
I'm thinking as performance, what type of difference is it going to give me having a cold air intake vs. Regular intake?
Old Nov 7, 2010
Kennykid2002's Avatar
Kenny the Ricer
It's called a short ram intake, or SRI
Cold air sucks up water if road is wet (because it's mounted very close to floor)
Short ram sucks up warmer air because it's located in the engine compartment
If you dont live in a place that doesnt constantly rain, then CIA would be better
Theres a thread on this forum where someone built a SRI out of PVC pipes, look it up
Hondata is like a couple hundred ~ 1G if you want to spend that much
Intake/exhaust/Header will only add minor performance, but nice sounds
Old Nov 7, 2010
Is there somthing I can mount around, or underneath the cold air filter to help prevent rain from being sucked up? Also sucking in air from inside engine bay, is the air realy that warm in there to were when I'm driving the car I'm sucking up warm or hot air.. I understand air from the ground will be colder, but is it really a significant amount colder?
Old Nov 7, 2010
I would just get a short ram. It's a lot simpler/cheaper and you will never have to worry about water. Trust me, I blew a head gasket when I sucked up water on my CAI. And that's not the worst that can happen.
Old Nov 8, 2010
Is you engine a B-series or D-series?
Old Nov 8, 2010
530matt's Avatar
530matt is an unknown quantity at this point
sucking up water should'nt be a issue if CAI is installed between bumper and inner fender plastic
if your still concerned use this,
http://www.aemintakes.com/air_bypass_valve.htm
spyder13
Jul 31, 2015 06:31 PM
Theshwartz35
Jul 17, 2015 11:13 PM
Genyc07
Wheels and Tires
Jul 11, 2015 05:51 PM
