speedo issues 98 dx
Old Oct 25, 2010
bgordon's Avatar
bgordon is an unknown quantity at this point
Exclamation speedo issues 98 dx
ok guys my car is a 98 civic dx hatch auto, car is throwing the obd2 code or vss range a performance speedo hasnt worked since i bought the car i have since then changed the vss with a new one bypassed the blue wire coming off of the vss running it straight to the ecu and even went as far as changing the speedo cluster itself with a known good cluster i took the ecu apart checking it for maybe burnt or loose solder joints and to no avail everything appears to be perfect im at a loss any suggestions to get my speedo working would be awesome i also wonder if the previous owner may have had a gps in the car because behind my cluster towards the drivers side there is a little electronic box with wires running into and out of it it also has a red light on it that flashes when the throttle is pressed any point past idle could this be the issue as well? again thank u guys
Thriftmaster
Vancouver
Apr 28, 2015 06:02 AM
crazybluehonda
Apr 22, 2002 09:50 AM
droidekaus
Mar 18, 2002 02:06 PM
hyperactive
Feb 4, 2002 04:12 AM
