Exhaust Swap
Re: Exhaust Swap
All you will need top put this on is a jack of course, 2 jack stands and a socket set. The socket for the bolts are probably 10mm or 12mm. All you do is unbolt the axle back from the resonator, then the resonator from the midpipe and the midpipe from the header. When you put it on start from the header then go back.
Oh and you will need some wd-40 or some pb blaster.
Re: Exhaust Swap
New gaskets wouldn't hurt, either. Don't do what I did and try and swap that **** hot.. The bolts are harder to unscrew and I damn near burned my hand on the cat.. lol
Re: Exhaust Swap
Lol.. This was back in my younger dumber days.. I had access to a lift courtesy of the navy, and I decided to use what I thought was something safe as an overhead hand rest while my buddy was doing something. Turns out it was a hot cat.. lol.
I always have a pair of mechanix gloves in my glove box.
Re: Exhaust Swap
Nah, its just when metal gets hot, it expands, and if there are dissimilar metals involved, then they're gonna expand at different rates. If they expand at different rates, then the threads are gonna have a lot more friction between them, thus making them hard to remove. Learned that the hard way as a mechanical engineer in the Navy.
Plus, I'd rather work on a cold exhaust system than a hot exhaust system.
edit: if anything, they'd be a bitch to get off due to years of being exposed to years of water and dirt.
Kcpowerhouse
Aug 1, 2015 06:55 AM
