Rear sway bar questions
Old May 25, 2010
Mavrick272's Avatar
Mavrick272 is an unknown quantity at this point
Now that I finally have my rear disc swap done I was looking into doing a 19mm RSX rear sway bar on my 1998 Civic LX to compliment the 22mm stock bar up front.
I've been told you have to do some drilling (because my model did not come with rear bars from the factory) and you also need subframe reinforcement (I was going to go with the ASR brace)
I'm new to suspension and I'm not exactly sure how everything fits together.
Can someone tell me where the endlinks attach? Do they attach to that hole in the lower control arm? (pictured) or is it somewhere else? Where can I get endlinks that will work? Will Grey's endlinks work, or should I get stock ones from a RSX?
I've also been told you have to drill out the existing subframe in order to attach the sway bar mounting brackets. It appears that my car already has these holes (directly above jackstands in pic)
Any advice/explanations would be GREATLY APPRECIATED!!
Thanks
Name:	mount holes.jpg
ID:	78370   Click image for larger version
Old May 26, 2010
ScottDR's Avatar
ScottDR will become famous soon enough
Re: Rear sway bar questions
You can bolt on an OEM 99-00 Civic Si bar as your car was manufactured with all holes/mounting space and bracket mount holes. I highly recommend this bar as it's not too large (14MM) as larger=oversteer especially in compromised grip (winter/rain etc). Plus it will definitely not rip out the control arms or mounting points on the body.
RSX will be much larger and the end links will be completely different, as were the Integra's.
Good luck.
Old May 27, 2010
Mavrick272's Avatar
Really????? That is amazing news! So all I need is the mounting brackets, bar, and endlinks?
(I found the endlinks at Beaks Products)
My car won't have the nut welded in there like the Si did. If I go to the Honda dealer and get the hardware will the bolts that hold the D-bracket on be long enough to put a nut on the end of?
http://www.honda-tech.com/showthread...=371907&page=2
(post #6)
Old May 27, 2010
grendel's Avatar
grendel has a spectacular aura aboutgrendel has a spectacular aura about
Man, you're gonna love this.
Wednesday night, I swapped out my 13mm for an RSX-S 19mm... immediately different car.
Going from NO bar to the 19mm ... wow you're gonna love this mod!
Old May 28, 2010
Mavrick272's Avatar
1. Screw the RSX bar. If I got that then I'd have to go with the subframe reinforcement....this girl is just a DD
2. I was looking at getting parts from Majestic Honda
Does anybody know if I need that spacer?
(part number 30 http://www.hondaautomotiveparts.com/...REAR+LOWER+ARM)
I'm assuming I do
3. Grendel - your bar wasn't from an 99 or 00 Si was it....? If so would you be interested in selling me the bar and brackets?
Old May 28, 2010
ScottDR's Avatar
Bar, brackets and end links. The nut comes with the end links and it's seriously a 20 minute job the first time you do it. The nuts are not welded on any of them as they all used exactly the same lower control arms.
Old May 28, 2010
Mavrick272's Avatar
What about Part #30? You can see it on Running Riot's post Fond Farewell: Goodbye Frankenstein (https://www.civicforums.com/forums/1...nkenstein.html)
It's about half way down, the shot with the rear LCA
Old May 28, 2010
Mavrick272's Avatar
I guess that's considered a bracket...durrrr...haha
Old May 28, 2010
grendel's Avatar
Naw, mine was from an '04 EL.
Sorry man!
Old May 29, 2010
Mavrick272's Avatar
That's alright. Thanks anyways though!
Old May 29, 2010
Mavrick272's Avatar
For anybody else doing this add on this DIY from our friends at Toronto Civic Club was EXTREMELY HELPFUL
http://www.torontocivics.com/article...r/swaybar.html
Old Jul 29, 2010
kcanoy's Avatar
kcanoy is an unknown quantity at this point
does anyone have a list of the sway bars that are direct bolt on to 2dr Civic EX 99?
Old Jul 29, 2010
lilmidget08's Avatar
lilmidget08 has a reputation beyond reputelilmidget08 has a reputation beyond reputelilmidget08 has a reputation beyond reputelilmidget08 has a reputation beyond reputelilmidget08 has a reputation beyond reputelilmidget08 has a reputation beyond reputelilmidget08 has a reputation beyond reputelilmidget08 has a reputation beyond reputelilmidget08 has a reputation beyond reputelilmidget08 has a reputation beyond reputelilmidget08 has a reputation beyond repute
just go with the stock si sway bar bolts rite in and not to overpowering, my civic handles better on the auto cross track then my friends evo with over 400 hp, i smoked him by over 3 sec, im using a stock d series just all suspension mods, she handles like she is on rails.
Old Jul 29, 2010
Mavrick272's Avatar
That's what I ended up doing, and she handles like a dream now. Definitely the best mod. i've done for the money
Old Jul 30, 2010
kcanoy's Avatar
know where i can get one for a good price?
Old Aug 7, 2010
Mavrick272's Avatar
You can probably get one cheap on eBay or on the classifieds on this thread. I got all my parts new from Majestic Honda.com and it ended up being WAYYYY cheaper than getting them from the local Honda dealer here in Grand Rapids. Final cost was around $200
Old Aug 7, 2010
Soldierboy87's Avatar
Soldierboy87 is an unknown quantity at this point
Could I just get one off a car in the junkyard?
Old Aug 7, 2010
grendel's Avatar
As long as it's from a compatible model, sure.
Old Aug 7, 2010
And is it really a noticiable difference when you drive. I just wanna see if it's even worth it.
Old Aug 7, 2010
grendel's Avatar
I've always been able to tell the difference, and right away.
Others that I've talked to haven't been able to notice the difference, though.
I guess it depends how attentive you are - some people won't drive without their music blaring... I don't even play music while I drive (I prefer paying attention to the car/road/wind/etc).
Will you notice it? It'll definitely make a noticeable difference, just depends on whether you're the type of driver who'll notice or not.
Old Aug 7, 2010
lordhelmet's Avatar
Good lord. You don't listen to music when you drive? I assume you are driving a civic so its not producing a particularly nice engine sound/exhaust note like me. How do you do it?
Old Aug 8, 2010
grendel's Avatar
LOL
I do on occasion. Not usually, though. Pretty much only when others are in the car with me and wanna hear something.
Too busy listening for things going wrong
Old Aug 8, 2010
lordhelmet's Avatar
This is exactly why I listen to music.
mrohitredd
Jun 9, 2015 06:37 AM
Rogelio Rey
May 24, 2015 08:30 PM
Dorval Andre
May 1, 2015 09:37 AM
bsmiley
Apr 27, 2015 01:27 PM
Firefly
Nov 28, 2001 06:13 PM
