replacing stock stereo with head unit
Old Apr 28, 2010
ianduh's Avatar
ianduh is an unknown quantity at this point
i dont really know much about cars at all, and after looking around i figured this would be my best bet as opposed to all the bullshit "tutorials" ive come across. I'd like to remove the stock stereo in my 2000 civic ex and install a head unit because my stock stereo scratches brand new cds and most of the time wont play them at all. im assuming ill need some sort of kit for the head unit to fit in but im not sure what kind or where the best place to get it would be. any help would be greatly appreciated. thanks again.
Old Apr 28, 2010
95-civic-slamed's Avatar
95-civic-slamed is an unknown quantity at this point
Re: replacing stock stereo with head unit
best buy will sell u a plug in and play kit i think the din cab is $22 and the wiring harness is $22 too! im 17 n ive been doin this for 4 yrs its easy all the wires r color coated
Old Apr 29, 2010
civicpapi's Avatar
civicpapi is an unknown quantity at this point
You can go to www.crutchfield.com, if you spend over $129 they give you free shipping, dash kit and wire harness, plus install directions, even a girl can do it. The dash kit and harness is worth close to 30 bucks by itself.
Old Apr 29, 2010
ianduh's Avatar
awesome sounds good thanks for the help guys
Old May 15, 2010
ianduh's Avatar
sorry to bump this old thread back up but i got everything i needed and installed the new receiver everything works fine on the receiver but my all my dash lights and all the lights that should come on inside the car when you turn the headlights on dont come on. any ideas as to why?
Old May 17, 2010
civicpapi's Avatar
Maybe a bad fuse?
Old May 17, 2010
SirCharlo's Avatar
SirCharlo is an unknown quantity at this point
Originally Posted by civicpapi
Maybe a bad fuse?
+1
Probably a fuse.
I was playing around with the obd2 thing once and i accidentally shorted something (lol), and boom! my dome light didn't work, and the warning chime didn't either.
Turns out it was just a bad fuse.
Did you hear a pop sometime during the radio install ?
Old May 19, 2010
ianduh's Avatar
sorry about taking so long to get back to this, i dont remember hearing anything abnormal during the installation but how would i tell if a fuse was blown? would i just be sticking out further than the others?
Old May 20, 2010
SirCharlo's Avatar
You can guess by looking at your manual to see which fuse could be blown (for example, the 7.5amp "Instrument Lights" fuse would be a good culprit ).
Go under your steering wheel, to the left, and remove the fusebox cover. Locate the fuse puller. Grab fuse puller.
Locate the "Instrument Lights" fuse (On the diagram, fourth one from the top. In the actual fuse box, it's on the top row, fourth one from the right.)
Remove that fuse. Check to see if it's blown. If so, replace it with a same-amp fuse (7.5).
Alternatively, you can take out all the fuses and look at them to see if they're ruptured (not recommended), or even better, use a multimeter to test the fuses' voltage (using a multimeter prevents you from having to pull out each fuse, you can just test on the spot). Read up here.
If you do this make sure to check all fuse boxes (under-hood, under steering wheel, etc.)
Old May 21, 2010
civicpapi's Avatar
I forgot how to test with a multi meter, I know that there 2 little metal tabs on the top of the fuses right? Do you ground the meter and then touch each tab to see if there is voltage? do you do it with the key on or off?
Old May 21, 2010
SirCharlo's Avatar
It's all in the page i linked to.
Key in acc position (motor off but fan on).
Black to ground, red to each dot on the fuse.
If DC voltage is normal, then fuse is not blown.
But really, read the page. It's not long and it's really well explained !
mugenca
Apr 16, 2015 12:15 AM
mwwhonda
Dec 5, 2001 10:52 AM
PimpBot5000
Nov 26, 2001 07:15 PM
BiGbRoWn
Bolt-on Engine Performance
Nov 21, 2001 06:17 PM
VORADOXX
Nov 20, 2001 01:09 PM
