Any ideas???
Any ideas???
I just replaced my rotors, brakes and driver side CV axle and have bee driving with no issues for a day or so before hearing a CLUNK? on accel in first(even gentle).. If i drive it around for a bit it will happen again but can't make it happen, so i can't quite put my finger on it..
It was my first time doing the cv myself, not a first for rotors or brakes...
If anyone has any insight, ideas or speculation it would be greatly appreciated.. Thanks
Re: Any ideas???
Yeah i torqued them to spec... so it's not the lugs.... i have checked and rechecked the brakes, bolts from everything i had to remove and replace(lower control arm,caliper bolts,etc...)still no idea...
Re: Any ideas???
yeah, i thought so... but now I'm questioning it. Just haven't worked on the axles before.. i don't know if it's relevant but the boots on my steering rack are ripped as well so i don't know that kind of issues(sounds) that could be contributing..
Re: Any ideas???
If you haven't figured it out...I definitely have an idea.
But first, you re-tightened all suspension bolts while under load of the car per the factory service manual correct?
If you did the above: Under hood on the shock towers are two mounting bolts (one front and rear) for the upper control arms. If not tight, make sure the suspension is under load. Then torque those bolts to the specified 40 ft/lbs.
SpecialRequest
Jul 7, 2015 07:52 PM
robbie374
Jul 7, 2015 02:56 AM
