Will this 02 work for a 00' EX
Old Jan 27, 2010
zXeX's Avatar
zXeX is an unknown quantity at this point
Is this the Upstream sensor?
Bosch 13007 Oxygen Sensor, OE Type Fitment
http://www.amazon.com/s/ref=nb_sb_no...6529&x=12&y=21
Old Jan 30, 2010
ScottDR's Avatar
ScottDR will become famous soon enough
Re: Will this 02 work for a 00' EX
Not sure if it will work but it definitely is NOT the correct Bosch part number for your car for either the primary or secondary O2 sensor.
Old Jan 30, 2010
bosch oe type is same brand as oem inside (NTK), but be sure about part number.
Old Feb 2, 2010
zXeX's Avatar
I picked this one up for the front bank -
Bosch 13371 Oxygen Sensor
Old Feb 2, 2010
ScottDR's Avatar
Good, that is the proper part number for your car.
Old Feb 7, 2010
zXeX's Avatar
Small issue now. I installed the new 02, and now, normally after the first few minutes following a start up, there will be some lag/stumbling in acceleration around 3K RPMs in 1st and 2nd gears... Sensor installed cleanly and didn't get damaged at all so I am stumped. Anyone else ever see this problem?
Old Feb 7, 2010
ScottDR's Avatar
Where do you live? Do you live in a cold climate? If so, pick up some IsoHeat (or other brand), fuel system water remover and pour it into the gas tank. I've had that once in the past 14 years of owning my coupe and it was just moisture in the tank from some crazy temperature swings we were having where I used to live. We had dropped 60 degrees F in 7 hours and a few other drastic swings all within a week (welcome to the upper plains). After putting the water system drier in the tank it went away almost instantaneously.
Now that I think about it, it happened most noticeably at a steady speed. Hmmm. Wonder if Gearbox has any ideas?
Old Feb 8, 2010
zXeX's Avatar
I am down here in Texas outside of San Antonio. Our temps have been somewhat stable lately... I Ran a code check and all I got was an IAT sensor code, bought a new sensor and all seemed well after install. Then the issue returned, but only shortly. The problem began the day after the 02 sensor install. But, the car ran fine during the test drive after the 02 install. .. so I am stumped. The problem doesn't cause any rough/irregular idle or stalling, just some stumbling upon normal acceleration, usually in 1st and second gear. between 1.5-3K RPMs.. It isn't an all the time issue .. just usually after the first crank up from sitting... It's simply like the car loses fuel for a few seconds, then regains it. I purchased some sea foam for fuel systems thats supposed to help remove moisture as well.. will dump it in when I fill up again... see if that helps any...
Old Feb 8, 2010
ScottDR's Avatar
Yes, Seafoam will help if you have moisture or some old gas. If not, when was the last time you replaced the spark plugs, distributor cap and rotor? What brand of plugs are you running?
Old Feb 8, 2010
zXeX's Avatar
Did the plugs about 3 months ago, running NGK Iridium IX's, and the engine ran smooth after install. I have yet to do the cap and rotor though. Thinking about doing that today... about to go fill up and sea foam it here in a bit though.
Question on the Cap and rotor.. What would be a good OE stand-in or brand, and where would the best place to be to get one? (like online perhaps) There are several auto-zones and such around here.. But i seem to play hell trying to find a decent part from them at times...
Old Feb 8, 2010
ScottDR's Avatar
I know Advanced can get in premium caps/rotors (brass inserts instead of aluminum) overnight. There standard ones seem to be ok as well but for a few dollars more you can get the better ones. Otherwise stop at a local dealer (probably the best quality you'll find). The premium paid to a dealer shouldn't be THAT great for a cap/rotor.
If you are buying more than just the cap/rotor you can certainly try: www.hondaautomotiveparts.com / www.hondapartsdeals.com / www.hondapartsunlimited.com The first two I've used extensively in the past with great success. Just keep in mind that shipping/handling will negate any savings unless you spend quite a lot.
Old Feb 8, 2010
those are nice, i think bluestreak is the brand with better terminals.
Old Feb 9, 2010
zXeX's Avatar
I will look into those. Today I may change out the fuel filter to see if by chance that may be the cause of the issue... The seafoam treatment hasn't cure it..
Old Feb 9, 2010
zXeX's Avatar
I didn't get the chance to pick up a fuel filter.. been a busy day. But, I was wondering, what is the average mileage out of a full tank of gas for a 1.6 coupe? D16Y8 engine... My mileage seems to be taking a dump again... About a little Below half a tank netted me 173 miles =/ Doesn't seem well at all .....
Old Feb 10, 2010
97 Civic coupe's Avatar
97 Civic coupe is an unknown quantity at this point
173 miles... gosh compared to mine that's amazing. My mileage suddenly dropped from 26 to 16ish. I'm lucky to get 190 on a full tank.
Old Feb 20, 2010
zXeX's Avatar
Well, installed new fuel filter plus cap and rotor (there was some medium carbon build up and cap was a bit toasty on the contact). Major hesitation seems to be gone, but there is still some tiny dead spots in the lower RPM band, still a clean idle though... I am going to replace the wires next, prob today or Monday. Been Waaaay too busy with a move and all.. Fuel mileage seems to be pretty good again. Filled it up, and got 75 miles on the clock so far and just barely starting to drop below the Full mark.... And that was with some minor flooring today..
Old Feb 20, 2010
whenever you do a big tuneup, wait at least one tank of gas for the ecu to learn the new conditions and adjust itself. the minor issues may clear up over time on their own.
Old Feb 20, 2010
ScottDR's Avatar
Or do the idle re-learn procedure and that should take care of it also. Here it is:
Idle Learning Procedure
On Hondas with OBD II, you can reduce current draw
during transportation or storage by removing the
memory backup fuse. Then when you reinstall the
fuse, run the engine for about 10 minutes after it
reaches normal operating temperature. This allows
time for the ECM/PCM to learn the proper IAC (idle
air control) values.
You also need to do this idle learning procedure
whenever you disconnect the battery or remove the
ECM/PCM.
Old Feb 21, 2010
zXeX's Avatar
Just something that has been on my mind .. what are my chances I received a faulty O2? I made a run earlier this morning and it hesitated again .. not bad, but def noticeable. And it Only does this until the car warms up, and it's always between 2.5K to 3.5K RPMs or so, and usually it is just the first run through the gears, after that, it is smooth.. Wouldn't a faulty O2 behave this way if the heater element isn't functioning properly? All of this began the next day after I installed the sensor (installed it the evening prior) I checked the wire harness and wires, all looks good and clean, no kinks or tears... I am still going to do the ignition wires and all .. Just wondering more and more about that O2... I guess if it still continues after the wires, I will look into getting another sensor =/ That and perhaps a new coil....
Old Feb 21, 2010
cas04571's Avatar
cas04571 is an unknown quantity at this point
i got on the same engine D16Y8 (OO) 205 max...changed spark pkugs (NGK) wires, cap/ rotor/ fuel filter, O2 sensors, pcv, air filter, and mufler. I do have cel on is the cat. Is that my problem..? don't kmow what else to do. Any sugestions I appreciated thxs.
Old Feb 21, 2010
cas04571's Avatar
Old Feb 21, 2010
zXeX's Avatar
Well, did wires today, already burned through a tank of fuel, still a no go as the hesitation was bad today (again, only through the first run of gears after starting the car, then it clears up and runs fine)... Ordered a new O2 for the upstream.. will try that again and will report back. I hope that's the issue (faulty O2), as I am running out of ideas. And since it coincidentally started with the install of a new O2, figured I would bank on it being a faulty one. I am going to clear the ECM/PCM memory tonight though for kicks and see if that does anything by chance before I pick up and install the once again. new O2... I didn't clear it the 1st time as I didn't think it would need that for an oxygen sensor install ...... live and learn if it works by chance I guess =/
Old Feb 22, 2010
zXeX's Avatar
Well, some possible good news. IF IT HOLDS OUT .. installed new Oxygen sensor, car runs stronger and smooooth through the gears. No surge/hesitation in acceleration at all... hope it stays that way. Even the throttle sounds alot better...
EDIT: Went on a drive again a few hours after the post above this sentence. Still runs perfect.
Old Feb 23, 2010
zXeX's Avatar
Another day, another tank burned (I drive alot). Still Runs Perfect. And mileage has improved. So all is well ... for now.
Old Feb 23, 2010
ScottDR's Avatar
Glad to hear it. They are very sensitive sensors and I can imagine physical damage could happen quite easily whilst in transport before install. Have you seen how things are handled during transport? Quite amazing there aren't higher failure rates IMO.
Old Feb 24, 2010
zXeX's Avatar
As one who orders alot of different things online (mainly photography gear from B&H) I def' see the abuse on some of the boxes. I have received boxes with good sized tears in them ... The sensor I ordered was loosely packed in it's carton so I should have known what to expect as far as possible damage goes...
Old Feb 26, 2010
ScottDR's Avatar
B&H and Adorama are great . Yes, UPS is a great destroyer of packages. I have tons of stories about them over the years, but I digress. Just glad you got your car back!
Old Feb 26, 2010
zXeX's Avatar
Sure enough, still running smooooth. Now I can continue my normal routine without the stress and second guessing of what was going on.
And yea, Adorama runs some good deals.. better prices at times than B&H, and Customer service is pretty good.
werdnahall
May 17, 2015 11:37 AM
cruisers10
May 12, 2015 10:46 PM
intensity
May 12, 2015 10:43 PM
ORskier
May 3, 2015 12:54 PM
cooldan1
Apr 23, 2015 10:49 AM
