automatic trans. problem...HELP!
Old Sep 12, 2009
theboss1974's Avatar
theboss1974 is an unknown quantity at this point
ok..so i am new here..and i have a 99 honda civic auto, we bought it used and it was always a bit tough to get from park into gear (I mean pulling the shifter from P to R or D).
So today, I took the shift **** off and sprayed some lube down it, when i put the **** back on for some reason it got even harder and the key would not come out of the igntion.
I then read online how to get the key out by removing the console and checking key lock switch and adjust the shift cable. I went through all the steps on the 'bulletin' PDF i found....now it wont go past reverse!! I cant get the car to shift from P to D....it will only go as far as R.
HELP!
Old Sep 12, 2009
Re: automatic trans. problem...HELP!
i think theres a problem with the shifter selector. it may be jammed up inside and also engaging the safety mechanism to keep the key inside.
Old Sep 13, 2009
i am able to get the key out now...but like i said its hard to get it to go to the R and will not go past..I have ALOT of the mechanism exposed now, but can see anything clearly wrong or jammed. Solenoid? bent linkage? i have no idea..
Old Jul 2, 2010
terry_b's Avatar
terry_b is an unknown quantity at this point
I have got the same problem in a 2001 civic. From P it wont go into R or any other gears. I use the shift lock release which is the only way to shift it out of P. However i was told it can be a blown fuse, but the fuse is not located in any of the fuse box. Im still wondering what causes this problem??????
danace99
Oct 17, 2015 02:51 PM
cferry7
Oct 3, 2015 04:33 PM
General DIY
Sep 25, 2015 08:02 PM
RSKtakR
Sep 24, 2015 02:18 PM
blizza
Sep 22, 2015 03:48 AM
