Dim Brake Warning light
Old May 24, 2009
bibitafarms's Avatar
bibitafarms is an unknown quantity at this point
My 2000 CX has a dim brake warning light. If I unplug the leed going to the master cylinder the light goes away; however, the warning light is much dimmer than say if you use the hand brake. Car stops just fine just wondering what might cause this. Many thanks.
Old May 24, 2009
CraigW's Avatar
Re: Dim Brake Warning light
If you have a DMM handy... Ohm out the switch contacts with the connector un-hooked and see if it reads open or actually has some resistance shown.
Old May 24, 2009
jagass's Avatar
jagass is an unknown quantity at this point
This is kinda tough...lol
Old May 25, 2009
sql_civic's Avatar
Make sure your brake fluid level in the master cylinder is correct. If it's low the brake light will come on. If you find that you need to fill it, then check it again in a few days to make sure you don't have a leak somewhere.
Old May 25, 2009
either youre low on brake fluid (could be caused from worn out brake pads), or your parking brake cable is messed. or you have a problem with the fluid sensor in the master cylinder reservoir.
Old May 31, 2009
Many thanks I think its the fluid sensor. After a week of checking no leaks and the pads seem ok not great but there is pad left. Wanted to ohm out the connections but my VOM went awol. Thanks for the helpful hints. Ps my cars a beater but I'm starting to understand the appeal of these 3 doors, very fun to drive even with an auto!
Xuhme
21
Aug 7, 2023 03:40 PM
MamaBear2015
May 27, 2015 12:04 PM
civic_gt
Apr 19, 2015 08:15 AM
smmahan
Apr 15, 2015 08:17 PM
SSMatey
Apr 13, 2015 06:09 PM
