Header buzz/rattle on 97 LX
Old May 28, 2009
jsoulier's Avatar
jsoulier is an unknown quantity at this point
Hey guys,
I have a 97 LX and the manifold cracked so I put a megan racing header pipe on it ($200 compared to $700 for the manifold and cat converter), did the O2 sensor spacer to trick the computer and everything is great except there is this buzz around 3-4k RPM when under load.
Any ideas how to solve this problem?
Thanks,
Jordan
Old May 31, 2009
Fanatic4Christ's Avatar
Fanatic4Christ is an unknown quantity at this point
Re: Header buzz/rattle on 97 LX
from the engine? maybe its something loose? did you bolt everything up good? is it the actual SOUND of the engine? or does it sound like rattle?
Old Jun 1, 2009
e-z's Avatar
e-z
e-z is an unknown quantity at this point
i have this same problem but only at idle speed. my whole exhaust starts rattling. it sounds right under the center console. where the headers/exhaust connect. i put in a different donut seal and have changed the size of the bolts, and also added this exhaust sealer stuff. it works fine for a month or two but it always comes back. its a pain getting under there every few months to re-do it. i hate pullling up to stop lights like this cause it sounds so trashy. .... u can try different bolts and the sealer stuff, c if that works for you. but if anyone has any ideas. id b intreste 2 know also
Old Jun 1, 2009
sql_civic's Avatar
The fasteners on heatshield on the downpipe is known to rust out. The heatshield will stay in place and not seem loose but it will rattle at certain resonant frequencies at certain rpms.
UltraHDGames
Jun 8, 2016 05:16 PM
HondaGuy7
Feb 22, 2016 01:00 PM
ThatGuy913
Nov 9, 2015 06:31 AM
jdh022764
18
Nov 3, 2015 06:44 AM
anubis62
Sep 27, 2015 12:56 AM
