moisture in headlights
Old May 15, 2009
Guso's Avatar
Guso is an unknown quantity at this point
is there a product they make to seal my headlights so they will o longer get some moisture in them so they wont turn yellow in the future
Old May 15, 2009
DeX's Avatar
DeX
Canadian, Eh!
DeX is a name known to allDeX is a name known to allDeX is a name known to allDeX is a name known to allDeX is a name known to allDeX is a name known to allDeX is a name known to allDeX is a name known to allDeX is a name known to all
Re: moisture in headlights
1. Go buy 1 square foot of fabric from fabric store
2. pop out headlight bulb
3. cut fabric to match contact points around headlight bulb, making a seal ring
4. apply sealing ring to bulb
5. insert bulb
Unless the air/moisture is getting in at some other point because they're cracked, then they're either getting in around the bulb or got in there at some point when you had the bulb removed.
Old May 15, 2009
DeX's Avatar
DeX
Canadian, Eh!
5. insert bulb
Old May 15, 2009
Guso's Avatar
thanks man. therre ebay projetors. not the ones with the circle reflector. there not cracked. il go and give this a try
General DIY
Sep 25, 2015 08:02 PM
eebing
Sep 12, 2015 05:35 AM
shaejb15
Sep 12, 2015 01:02 AM
Bricoleur
Sep 9, 2015 12:23 PM
MamaBear2015
Sep 4, 2015 09:04 PM
