Need headlight help
Old Mar 23, 2009
JRoX85's Avatar
JRoX85 is an unknown quantity at this point
Need headlight help
ok, so I just traded for a 2000 civic ex and the headlights only work on high beams. also gauge cluster lights are out. what could be my problem?car does have an h22 swap in it, I dont think that would affect anything though or would it? thanks for the help, and please if you have nothing nice to say keep it to yourself and be mature about it.
Thanks,
Jason
Old Mar 23, 2009
Re: Need headlight help
are all the other dash lights out too? could just be a fuse blew. same for the headlights, or a relay maybe went bad. check the wiring out and see if it looks fine. may be the switch went bad too.
Old Mar 25, 2009
JRoX85's Avatar
yes dash lights are out as well LOL I pulled cluster today and all plugs seem to be intact except one but there is no place to plug it in on the cluster and I really suck at electrical
Old Mar 25, 2009
cluster should only have two plugs i believe that connect it to the wires. did you check the fuses under the dash above the brake pedal? it sounds like you blew the "small light" fuse.
meicalnissyen
Sep 25, 2015 12:12 AM
rnaodm
Sep 21, 2015 12:42 PM
shaejb15
Sep 12, 2015 01:02 AM
Bricoleur
Sep 9, 2015 12:23 PM
MamaBear2015
Sep 4, 2015 09:04 PM
