e-brake help!
Old Mar 4, 2009
flipcivic's Avatar
flipcivic is an unknown quantity at this point
e-brake help!
i have a 2000 civic ex.. im having a problem with the e-brake. everytime it is like freezing cold, my e-brake does not go all the way down. when you release it, it goes up almost half way. can anyone help me???
Old Mar 5, 2009
ScottDR's Avatar
ScottDR will become famous soon enough
Re: e-brake help!
Yes, most likely one, or both, of your e-brake cables has become rusted inside. Time for a replacement or take them out and inspect both to find which one is the culprit.
Edit: Actually after re-reading, it only happens when it is cold. Therefore you have water in at least one of the e-brake lines and it's freezing. Therefore, find the source of moisture getting into the affected cable, dry it out and seal it back up after spraying in some thin lubricant.
Old Mar 5, 2009
shadymechanic's Avatar
shadymechanic is an unknown quantity at this point
Re: e-brake help!
Inspect lines, clean rust - any, and lube it. Honda's like to freeze up in winter - it's their M.O. Check for moisture like was suggested. You might have to replace the parking brake lines. That's what i had to do with my 96 civic LX.
Old Aug 8, 2009
StickyRice's Avatar
StickyRice is an unknown quantity at this point
Re: e-brake help!
Is there a write up on replacing the brake lines? I couldn't find one...continue my search...
JohnnyBxo
Nov 12, 2015 03:04 PM
blward6
Sep 16, 2015 05:32 PM
SatansEnemy
Mar 30, 2003 10:41 AM
Jamers
Transaction Feedback
Mar 7, 2003 10:50 PM
Jujarso
Feb 25, 2002 01:26 PM
