Throttle Response gone ........................... :(
Old Feb 4, 2009
mefi's Avatar
mefi is an unknown quantity at this point
Hi everyone,
I hope somebody here will be able to help me
Mods: cheap SRI / 4-1 H / de-cat / greddy evo2 cat back exhaust
I have a problem with my 6g 99’ b16a2. After I have changed the headers to stainless 4-1 and put a de-cat the car has lost throttle response on low revs.
I don’t know much about cars, but I presume that the air fuel maps should be adjusted after those changes. Unfortunately I don’t know a place where this can be done.
Can somebody tell me please how can I increase this without changing back to OEM. Would a CAI do the trick ? Apparently the CAI acts negatively on the throttle response comparing to a SRI…. (?)
Thanks a lot !
( sorry for my English )
Old Feb 5, 2009
cmy_civic's Avatar
cmy_civic is an unknown quantity at this point
Re: Throttle Response gone ........................... :(
Um, well ive heard some bad things about the 4-1 headers. I was always recommended to get 4-2-1 headers. So MAYBE its the headers, but im not too sure either.
Old Feb 9, 2009
guachi's Avatar
guachi is an unknown quantity at this point
4-2-1 headers are better... map sensors need to be adjusted as well, take the battery possitive wire for 5 minutes, then connect it back and turn on the car let it stabilize and go to its iddle range, then go for a drive and see if it helps any... they're OB2 compliant so that's one thing to watch for...
Old Feb 15, 2009
ScottDR's Avatar
ScottDR will become famous soon enough
4-1 headers are not a problem unless they are horrible quality-I'd use Honda only, and do. I would NEVER recommend removing the cat. Get a high flow cat instead. Besides spewing unburned hydrocarbons into the air, the exhaust note becomes much more fart-can like. You most likely have a CEL now as well without the cat, right?
Zygrene
Mar 22, 2016 12:36 PM
Bruce2
Sep 27, 2015 08:45 PM
Matt T
Idle Issues
Sep 24, 2015 04:53 AM
Bricoleur
Sep 9, 2015 12:30 PM
Stock 99
Sep 5, 2015 06:06 AM
