98 Civic LX power window problem
Old Nov 11, 2008
Mavrick272's Avatar
Mavrick272 is an unknown quantity at this point
The passengers' side power window will go down, but not up
It is getting power, and I can hear a click ONLY when I try to lower the window (the window is all the way down)
any ideas/suggestions?
thanks
Old Nov 11, 2008
CraigW's Avatar
Re: 98 Civic LX power window problem
With the engine off but key on position II... Turn on the dome light and watch it as you try to move the window up. See if and how much it dims the dome light as as you try moving the window. If it dims quite a bit then something may be bound (although you said it would go down) If it does not dim...it could be voltage not reaching the motor.
Old Nov 28, 2008
97EXSweetSusie's Avatar
97EXSweetSusie is an unknown quantity at this point
I had this same problem with mine and it got stuck down so i hard wired it to the battery real quick just to get it up. then i replaced the master switch on the drivers side and it fixed the problem so check that but the problem i have now is that for some reason a week and a half later same problem hapened with this master switch
Old Feb 12, 2009
Mavrick272's Avatar
From my understanding the window regulators on these cars are pieces of ****, very poorly designed.
I got the regulator replaced at a mom and pop auto repair place for around 70 bucks, including labor
Old Feb 22, 2009
Mavrick272's Avatar
The regulator died and apparently when it died it also shorted out my switch
So now I'm waiting on a new switch
Dorval Andre
General 7th Gen
34
Jun 3, 2024 08:11 PM
bsmiley
Apr 27, 2015 01:27 PM
mdd5
Apr 21, 2015 06:54 PM
NoToRiOuSxPiNoY
Bolt-on Engine Performance
Nov 7, 2001 11:19 PM
mj1010
Aug 26, 2001 09:52 PM
