big problem, loud clanking, engine light
Old May 19, 2008
himhimself's Avatar
himhimself is an unknown quantity at this point
so i was driving on the highway when all of a sudden i felt something that felt like a transmission slipping, except i was in low rpm's and it wasnt ready to shift. Following this, was a clanking noise that only happened when acceling...i noticed a tremendous loss of power though but my car could still make it home cuz i wasnt far away. Once i got it home i popped the hood and the noise sounded like it was coming from the block or lower and i smelt a hint of burning oil. so i checked the ground and no oil was coming out
i have a 1998 honda civic ex automatic
any ideas?
Old May 20, 2008
Re: big problem, loud clanking, engine light
either sounds like a broken timing belt, distributor (which could throw the timing off), or some other internal engine problem. have that light checked with a scanner to see what code its giving.
Old May 20, 2008
SWHaUnTsMe's Avatar
SWHaUnTsMe is an unknown quantity at this point
Don't know offhand, but I had a similar problem with mine about 2 years ago. 5th gear at highway speeds, heard a strange knocking start, started slowing down and it got louder. Then there was a loud crack, all lights on the dash popped up and the power of the car went bye-bye. Pulled over, found a hole in my oil pan and found cause was a thrown rod. Goodbye engine.
Here's hoping that's not what happened with yours, but the symptoms are somewhat the same. Clanking noise for me though, was all the time, as soon as you turned the car over it did it.
Good luck.
Old May 21, 2008
himhimself's Avatar
yeah the clanking is all the time...when it starts up ....idling u cant hear it...and touching the gas u can again
i noticed last night that oil was coming out of my pan!...so i drained the oil (only had a qt or two left in it) ....tightened up all the bolts to the oil pan, and put more oil in it...the sound diminished a little bit but was still there
Old Jun 14, 2008
sql_civic's Avatar
Sounds like you spun a bearng.
Xuhme
21
Aug 7, 2023 03:40 PM
hernandexz
Oct 28, 2021 10:52 PM
thana
Jun 15, 2020 07:05 PM
tylerginevan
Apr 27, 2015 12:29 PM
dooner24
Apr 14, 2015 07:51 PM
