New Rims having a problem
Old Apr 9, 2008
himhimself's Avatar
himhimself is an unknown quantity at this point
i jest put a set of 17" inch Enkei rims on my car and if i have more then 2 people in my car (including myself) it bottoms out a lot and scrapes the inside of the fenders...i was thinking about dropping my car slightly but now i am having concerns about doing this
but then i thought...if i drop the car will the suspension be stiffer? stiff enough to maybe solve this problem?
Old Apr 9, 2008
dk1021's Avatar
dk1021 is an unknown quantity at this point
Re: New Rims having a problem
So you're on stock suspension and you're still scraping?
That's kind of weird ... you could get some shocks that have the stiffness adjustments. Don't know how much that'll help. If you're planning on dropping, you can also get a camber kit to make the tires a little negative. Downside is you'll sacrifice the life of your tires. I have 17" enkei as well and i rarely scrape even with people in my car and i'm dropped about 2". What model/offset are you rims?
Old Apr 9, 2008
HighBoost's Avatar
HighBoost is an unknown quantity at this point
well..these two ppl in ur car must = lots weight. u can just have another two ppl sit in ur car .. u standin outside of the car and see if is the tire bottoms out or it might just be somethin else ..
Old Apr 10, 2008
himhimself's Avatar
ok so i put all 4 rims on...and it still scapes when i have 3 ppl in the car including myself...
i had 4 in my car yesterday and i couldnt fit a finger in between my tread and the little bend on the inside of the back fenders
Old Apr 10, 2008
cinaibur's Avatar
cinaibur is just really nicecinaibur is just really nicecinaibur is just really nicecinaibur is just really nicecinaibur is just really nice
what size tires do you have?
Old Apr 10, 2008
tuningmycivic's Avatar
tuningmycivic is a name known to alltuningmycivic is a name known to alltuningmycivic is a name known to alltuningmycivic is a name known to alltuningmycivic is a name known to alltuningmycivic is a name known to alltuningmycivic is a name known to alltuningmycivic is a name known to all
^ ditto, and what is the offset and width of your rims?
Old Apr 11, 2008
himhimself's Avatar
my tires are 205/40
and im not quite sure what the offset is
Old Apr 11, 2008
j.steimer04's Avatar
j.steimer04 will become famous soon enough
Your suspension has got to be wasted! I would agree with everone saying to run stiffer suspension.
Old May 17, 2008
ONE7thREBUILT's Avatar
ONE7thREBUILT has a spectacular aura aboutONE7thREBUILT has a spectacular aura about
Combined weight of all three people & the last time the car got at least three feet of air with all three people in the car?
Old May 19, 2008
himhimself's Avatar
lol i dont take my car airborne
Old May 20, 2008
if you are at stock ride height and scraping, you dont lower the car lol. get some new shocks would be my guess. if they dont work, you end up pretty much riding on the spring, which can compress quite a bit going over bumps and cause car to bottom out.
Old May 27, 2008
97blackexgirl's Avatar
97blackexgirl is an unknown quantity at this point
I have the same problem with mine, I'm running 18's with 215/40 tires, depending on how old your car is it's probably just shitty shocks, mine are shitty, but I found that if your take anything like a breaker bar or even something that is round and fits in between your tire and fender, you can easily roll your fenders. This eliminated the prob for me big time, but now I got a massive stereo in my trunk and well that don't help, now my tires are tucked, but hey, they don't scrape anymore!!!
jbander
Wheels and Tires
Jul 10, 2015 05:26 PM
Lopes101
Jun 7, 2015 08:04 PM
HomelessSanta
May 14, 2015 09:53 PM
Pudnite
May 9, 2015 07:51 PM
