timing belt question
Old Apr 5, 2008
koey03's Avatar
koey03 is an unknown quantity at this point
hello everybody..
i'm new to this forum. bought a 96 civic coupe 5spd EX recently. i just had the timing belt, water pump and all belts changed at 89000 miles by a local mechanic shop using all OEM parts. however, the belt was making some noise when it stops and idle, around 700-800 rpm, the mechanic said its normal to new timing belt. the car runs no problem tho. just wanted to see if its true or have I got fooled by him? shouldn't it be more quiet since i had this tune up? any kind of information will be appreciated. thanks!
Old Apr 5, 2008
ex-cobalter's Avatar
ex-cobalter is an unknown quantity at this point
Re: timing belt question
the belt doesnt just make noise, something is out of adjustment for it to be doing that.
Old Apr 5, 2008
koey03's Avatar
so its because of the timing belt too loose or tight?
Old Apr 8, 2008
fine50's Avatar
fine50 is an unknown quantity at this point
is there any noise above 800 rpm? you should ask your guy if he checked the belt tensioner for a rough bearing, if he felt any roughness he should have replaced it. he is giving you bs when he says noise from the belt is normal.
Old Apr 8, 2008
the Idler Pulley Bearings are gone, get a new pulley set-up, and your problem will go away
Old Apr 8, 2008
koey03's Avatar
there's no noise after 800rpm...the car runs fine...so does it mean i have to replace the tensioner again?
Old Apr 9, 2008
yuppers. and if you are doing it yourself, a little white lithium grase never hurt anyone, yet
Old Apr 11, 2008
lemac's Avatar
lemac will become famous soon enough
An over tighten timing belt will make a noise at idle as well. Been there done that. Not saying thats your case, just keep it in mind. Always good to start with the easiest and least expensive fixes first, and work your way through the other variables.
mattdoc
Mar 14, 2017 12:10 PM
dosmastr
May 5, 2015 12:19 PM
MN-02-CivicEx
28
May 2, 2015 09:11 PM
bsmiley
Apr 27, 2015 01:27 PM
dano2005
Apr 14, 2015 01:58 AM
