Where is the fuse of the Front fog lights?
Old Jan 11, 2008
djc1978's Avatar
djc1978 is an unknown quantity at this point
I had to change the Left front fog light and i may have caused a short-circuit and blown the fuse.
I went to check the fusebox inside the car but there was no fuse where it was supposed to (according to the diagram).
The fog lights were always working so the fuse must be elsewhere in the car.
I tried the fusebox on the hood but there was no mention of a fog light fuse.
I bought the car with the front fog lights so it must have the default factory installation.
Can somebody tell me where is the fuse hiding?
Obrigado.
Old Jan 11, 2008
Nitro Express's Avatar
Nitro Express is an unknown quantity at this point
Re: Where is the fuse of the Front fog lights?
Fog Lights have an in-line fuse. Wire should be red & white. Sorry, not sure where it is, I'd try and trace the wire. Good luck.
Old Jan 13, 2008
djc1978's Avatar
Ok. Found it!!!
It was inside the car, by the upper left of fusebox.
It really is hiding behind the lower paner and some plastic pieces.
I found it by following the wire from the switch.
The Honda guy that came up with this should get an award for cleaverness and simplicity !"$$%!#%$#
Thanks nitro!
Thinking that you're MacGyver: free + too much TV
Blowing a fuse because you're not: also free
Going to a certified electrician to clean up the mess: 25 € / hour
Learning how to do it yourself and believe u're MacGyver again: priceless
Exterior
Nov 28, 2025 05:23 PM
CivicS
Nov 22, 2001 10:51 AM
klam
Nov 19, 2001 05:46 AM
klam
Nov 16, 2001 03:36 PM
WhosYoDadday85
Nov 11, 2001 05:41 PM
