Clutch problems ...
Old Oct 26, 2007
Tommy O's Avatar
Tommy O is an unknown quantity at this point
Clutch problems ...
On my 96 civic EX; the clutch pedal has simply gone "limp." The pedal goes straight to the floor, and I obviously can't get in or out of gear. Does anyone know if this is a slave cylinder problem? No fluid leaking, has been getting harder to shift over the past week or 2, finally gave out a couple of days ago. Need some help or advice please!!!
Old Oct 26, 2007
FGCOUPE's Avatar
FGCOUPE is a name known to allFGCOUPE is a name known to allFGCOUPE is a name known to allFGCOUPE is a name known to allFGCOUPE is a name known to allFGCOUPE is a name known to allFGCOUPE is a name known to allFGCOUPE is a name known to all
Re: Clutch problems ...
if the pedal is on the floorboard, try the spring on the pedal?
if its just limp then maybe the pressure plate is gone?
if its slipping the clutch disc is gone?
Old Oct 26, 2007
RonJ's Avatar
RonJ will become famous soon enough
Just a thought. Did you happen to look for a fluid leak from the clutch master cylinder where it is engaged by clutch pedal inside of car?
Old Oct 27, 2007
lordhelmet's Avatar
Its most likely the slave cylinder. Not to hard to replace.
Old Oct 27, 2007
Tommy O's Avatar
It was only slipping if I shifted low into the next gear (usually @ 1500 rpm); and only for a split second.
Old Oct 27, 2007
Tommy O's Avatar
No leaking fluid at the master, as a matter of fact, it was full when I checked it. I had my wife pump the clutch and there was no fluid movement in the master at all. At the master inside the car, I found no leak. Although I'm going to recheck the return spring now, Thank for the advice!
Old Oct 27, 2007
FGCOUPE's Avatar
My advice to you and anyone else....
always start with the small stuff like a spring, clutch cyl. etc...
then if that all check out ok, then move onto the bigger parts like the master, clutchplate,disc, etc...
go the other way, and itll cost ya more then it was worth at the end of the day.
Old Oct 27, 2007
Tommy O's Avatar
Damn good advice, thanks
Old Oct 27, 2007
Tommy O's Avatar
Well, thanks to you guys...I changed the slave cylinder and she's on the road again. I appreciate the help.]On to the next project......
Old Oct 27, 2007
RonJ's Avatar
Good call by Lordhelmet
Old Oct 27, 2007
lordhelmet's Avatar
Thanks... Have had that problem before.
dinsum
May 28, 2015 09:30 PM
pantdino
15
May 13, 2015 02:22 PM
crowtoo
May 11, 2015 06:50 PM
MN-02-CivicEx
28
May 2, 2015 09:11 PM
delacampos
Transmission
Jan 2, 2002 02:06 PM
