'97 Dx Headlights "Flicker"
Old Apr 8, 2007
Viper42391's Avatar
Viper42391 is an unknown quantity at this point
When driving at night, the headlights on my Civic dim, and then go back to full strength. They will do this every 5 seconds or so. It seems that it only happens when sitting at a light, or drifting in neutral, not when cruising or accelerating. Has this happened to anyone else? Anyone know how to fix it?
Thanks!
Old Apr 8, 2007
sql_civic's Avatar
Re: '97 Dx Headlights "Flicker"
Well, I'm just guessing really but...
Check your battery. Make sure it's good and that the cables have a clean tight connection.
Check your alternator. If you have over 180,000 miles it may be time for a rebuild. It could also be the voltage regular (inside the alt). Make sure your connections are sound on the alt and that the belt isn't slipping.
Good Luck.
Old Apr 8, 2007
Viper42391's Avatar
Thanks for the advice... I am planning on taking it in to my school (we have an auto tech class) because they have a battery load tester, so I can see if the battery is still good. I'm not sure how many miles are on it... I'll check tomorrow, but I think its around 90000 if I remember correctly. Maybe i'll check the battery connections tomorrow also.
meicalnissyen
Sep 25, 2015 12:12 AM
rnaodm
Sep 21, 2015 12:42 PM
shaejb15
Sep 12, 2015 01:02 AM
Bricoleur
Sep 9, 2015 12:23 PM
MamaBear2015
Sep 4, 2015 09:04 PM
