2002 Civic immobilizer question
Rep Power: 0 2002 Civic immobilizer question
Good Morning,
I apologize in advance if this question has been answered before. I read quite a few threads, but all are about the green key light blinking or staying on. My problem is that the car cranks but does not start. There is no green light whatsoever, not when I insert the key, not when I crank, and not when I take the key out. Would it be wise to assume that the immobilizer unit is dead? Would replacing it with a new one off ebay, buying the SBB key programmer, and programming them myself be cheaper than having the dealer do it?
Thank you in advance!
Re: 2002 Civic immobilizer question
Hopefully your ECU popped a fuse, that light is controlled from the computer and if it’s not comming on and your car is cranking but not starting you need to plug a code reader in and see if there is any sign of life.
Test, don't guess.
No flashing green light at all = suspect lost power to the unit. Fuses? Relays?
Does the CEL also no longer light up when you turn the key on? (More clue)
Rep Power: 0 Re: 2002 Civic immobilizer question
I began the troubleshooting by checking common causes to the "crank but no start" problem (before I realized the green key light didn't turn on). I checked fuses, changed both blue and brown relays under the glove box, checked rocker arm, and even unplugged battery overnight as a last resort. I'm stuck. Almost as maddening as figuring out the misfire on my RX-8. I will check fuses again to make sure. Does the orange light around the keyhole mean the unit is at least getting power though? Or is that not part of the immobilizer?
If you take off the column covers there are 2 green connectors on the 2 units by the keyhole. Immobilizer is the plug with 7 wires
Crappy incomplete diagram courtesy of goggle images
What you can't see here in the immobi CU:
Immobi CU wire #7 is constant power source from fuse #9 in engine compartment
wire #5 directly controls the green key symbol light
Between #2 and IMOCD lies the underdash fusebox
Between #1 and LG3 (logic ground) there are a couple of large harness connectors
The green key light should blink several times after you turn the ignition off.
If you have constant power to 7, switched power to 6, and good ground on 1 (I know I've seen issues with the ground in the past), and you can make the green light blink by supplying a ground to #5, then the immobi ring should be at fault.
Replacement unit must be programmed.
thumbelina
06-12-2019 08:42 AM
chuyg13
06-01-2014 02:13 AM
Jdm01Em2
11-26-2006 10:50 PM
