Ignition immobilizer problem
Old Oct 8, 2014
sandman66's Avatar
sandman66 is an unknown quantity at this point
Just bought a used 2002 civic and am finding a few issues the previous owner never mentioned. Biggest problem is about a week after I bought it I went to start it one day and when I turned the key nothing happened. This happened a few times before I noticed a green "key" idiot light flashing on dash. I dug out the manual and it says there is some kind of immobilizer. One thing it mentioned was to not have any other fobs on the keychain, which I didnt. I even took every other key off the ring. I have had the car a few weeks now and the problem is on going, happens every 4th or 5th time I try to start it. Usually I take the key out , wait till the light stops flashing then try again and it starts. But a few times it has taken several attempts. A couple times it turned over for about a half second before it shuts down.
So can I fix this, or is there a way to disable the immobilizer?
Thanks
Old Oct 8, 2014
lowlife9's Avatar
Re: Ignition immobilizer problem
could also be the ECU or the key itself does this happen with your spare key also ???. side note there is a brake pedal code you can enter if you ever get stranded because of the Immobiliser you can get the code from a honda dealer.
Old Oct 8, 2014
Read the manual about what you should and should not see that green light do, when it should and should not flash.
The immobi system does not have "starter cut" on that car. If should crank no matter if the immobi system sees the correct key or not.
Does it have remote start? Odd antenna on the inside of the windshield?
Old Oct 9, 2014
CraigW's Avatar
Get any extra keys ??
Try them for a while.
Old Oct 9, 2014
Weak battery or low battery voltage can cause the immobilizer to not work right too.
Old Oct 13, 2014
LADD4832's Avatar
LADD4832 is an unknown quantity at this point
I changed my daughter's battery and the lingering flashing green key problem went away.
Old Oct 14, 2014
sandman66's Avatar
Ezone- You are correct, Dealer told me it would still turn over so I am guessing the problem is not the immobilizer. It has a newer battery and it tests good. I am now thinking there may be a loose connection somewhere as the problem didnt start till at least a week after I bought the car, and is getting progressively worse. If I get a chance this week I am going to make sure battery connections are tight and perhaps the starter as well, if I can find it. Otherwise its going to the dealer Friday. I can 't afford to get stranded.
Old Oct 14, 2014
CraigW's Avatar
^^^Check all major grounds, in snow/ice/salt areas they get nasty after many years.
Old Oct 21, 2014
sandman66's Avatar
Thanks guys. A couple days before it was booked into the dealer the problem mysteriously disappeared. I showed up for my appointment but the advisor agreed I should just leave it for now. Been a week with no problems. I'm guessing there is a wiring issue somewhere, will hope for the best.
CarStuff
Dec 6, 2020 12:52 PM
01civyv3
Jun 2, 2015 05:21 AM
pincookie1
May 4, 2015 12:22 PM
Gunner
Engine DIY
Oct 6, 2012 12:37 PM
Doc
Dec 12, 2001 11:47 AM
