Mechanic/Dealer at a loss - 02 civic cranks but will not turn over
Old 01-25-2019
Yossi's Avatar
Yossi is an unknown quantity at this point
Sometimes it will start 50 times in a row, other times it will crank and crank but not start. The engine is spinning during the crank because power steering is working. Charging system is fine. Fuel is fine. Spark is fine. Nothing showing up on the scanner, no CEL, not throwing any codes. Computer tests fine.. On a hunch, replaced the crank sensor, but no luck. Local mechanic is best in the town and cannot figure out. Had it towed to the dealer, worked on it for a few hours, cannot find anything. Really hoping for any creative thinking here so I don't have to junk her.
Yossi is offline
Old 01-25-2019
Re: Mechanic/Dealer at a loss - 02 civic cranks but will not turn over
Toss a pair of fresh main relays at it?
ezone is offline
Old 01-26-2019
Slumpertcivic's Avatar
Did you try disconnecting the crank sensor and seeing if it starts up?
Slumpertcivic is offline
Old 01-26-2019
Dr Krieger of Modification
mac25's Avatar
That's a somewhat common issue on the 2002.
It happens on mine as well, its something to do with the anti theft immobilizer, I think.
Mine works 100% of the time if I turn the key until i hear the pump prime, then off, then same position, wait until you hear the pump, then start.
You could also check your immobilizer antenna for loose connections.
mac25 is offline
Old 01-26-2019
Seems like many of the cars want an extra second or two of cranking when the fuel level is 1/4 tank or less
ezone is offline
jemerson
03-07-2019 10:32 AM
Ted-04
02-05-2019 01:52 PM
Shavalavo
Engine start problems
17
09-02-2018 12:39 PM
CraigDillon
06-30-2017 09:14 AM
MegaHurtz
02-19-2010 01:39 PM
Quick Reply: Mechanic/Dealer at a loss - 02 civic cranks but will not turn over
