So I have a spare tranny EL 2004 from JY, because mine in my 2001 EL Acura is making noise now on input shaft bearing like when clutch is out and in gear 1-3 and getting louder even in high gear highway speed.
Reason is it is expensive bringing it to the shop and it id better to do-it-myself sooner with my buddy here.
My question is could I buy any aftermarket or OEM replacement clutch kit which the least cheaper but somehow reliably ok, that within this generation 2001-2004, like e.g. EXEDY, MPACT, LUK,VALEO, SACHS etc? idk which are better above I have mentioned I know I heard alot of Exedy for only $150 in Amazon.
Any advice on this would bevawesome.
Thanks in advance!!!
ELfred
ELfred
sdaidoji
close
- Join DateDec 2008
- LocationTN
- Age54
- iTrader Positive Feedback100
- iTrader Feedback Score(1)
- Liked:1,605 Times in 1,330 Posts
exedy works well for me.haven't used the others, so don't know
Colin42
close
- Join DateFeb 2016
- LocationBarrie, ON Canada
- iTrader Positive Feedback0
- iTrader Feedback Score(0)
- Liked:1,283 Times in 1,080 Posts
Used excedy in mine worked well
Hello! nice thanks to both of you.
Will EXEDY fit on any of this year?
I think there tranny from year model 2001 to 2005 have the same design, please qoute me on this. I might be wrong.
Thanks!!!!
Elfred
Thanks!!!!
Elfred
Colin42
close
- Join DateFeb 2016
Yep it's the same although VTEC and non VTEC trans have different gearing, but you already have another VTEC trans so you're good. You will need a couple 12 point sockets for the pressure plate and the flywheel, I can find the sizes tomorrow.
When I swapped my trans I did the clutch at the same time in the driveway.
I too used a exedy kit, seems to work very well.
You would do well to replace the engine rear oil seal while you have the tranny out.
Speakig of which, you also should install new axle seals in the tranny.
Originally Posted by Colin42
Yep it's the same although VTEC and non VTEC trans have different gearing, but you already have another VTEC trans so you're good. You will need a couple 12 point sockets for the pressure plate and the flywheel, I can find the sizes tomorrow.When I swapped my trans I did the clutch at the same time in the driveway.
Ok my question is can I re-use the 12-point socket of 10mm and 17mm again? or bought/install new one?
Thanks alot!
Elfred
Quote:
Yes ok, those seals, I'll ask honda dealer here in my place, btw do I need to drain the engine oil too on my D17A2 while doing the rear oil seal?Originally Posted by Slumpertcivic
Elfred
Colin42
close
- Join DateFeb 2016
Thanks alot!
Elfred
Do you mean the bolts?Originally Posted by elfred
Thanks alot!
Elfred
you can reuse the bolts
Lol sorry my bad, yeah it is the bolts.Originally Posted by Colin42
Do you mean the bolts?you can reuse the bolts
ok thank you!!!
Elfred
A little oil will come out that was puddled behind the seal.
Couple wipes inside the gap should stop the flow.
Hello slumpertcivic thank you so much, but do I need one doin this rear main seal job if inbetween is still intact on no leaking yet at all? I mean they are yet dry and clean underneath this engine bay, Just saying Thanks again!
Cheers!
Elfred
Cheers!
Elfred
Of course you don’t have to replace the seals, in fact later down the road when it does start leaking you still not need to replace it.
Then as some point when you decide it’s leaking too much, you will be familiar with how to take that transmission out again.
