Trashed Lower Control Arms
Old Dec 1, 2018
Nimbus's Avatar
Nimbus is an unknown quantity at this point
Think this just might of been causing that occasional clunking noise?
Old Dec 1, 2018
GolNat's Avatar
Prelude Owner
Re: Trashed Lower Control Arms
Yikes!! Yes you have found the problem!! Now to decide to buy new control arms or just bushings and pop those out.
Old Dec 1, 2018
Nimbus's Avatar
Yes,replacing with new complete LCAs. Basically replacing the entire suspension. Rock Auto is getting a nice chunk of change from me. And I will have a decent suspension Struts and mounts were pretty trashed as well. Springs were in good shape, but am going the lazier route and got the quick struts. Replacing ball joints, tie rod ends, and stabilizer links as well. And then next will be all the engine/transmission mounts.
Saying the prior owner neglected the vehicle might be to strong of a statement, but definitely was just replacing things as they total failed and/or caused noticeable problems. Receipt for replacing both axles/CVs, because driver was complaining of noise, about a year back. Hard to believe those bushings weren't well on there way out at that point as well.
Old Dec 2, 2018
Keep the arms, replace bushings at your leisure, and next time you need them, just swap the old one with new bushings in
I have my old set in the shelf
but boy, this is bad...
Old Dec 2, 2018
Nimbus's Avatar
That is a good idea. I may do just that!
-Nimbus
Old Dec 7, 2018
jdh022764's Avatar
jdh022764 is an unknown quantity at this point
that is very common, that is why i have a press in my garage
tgrudzin
Aug 8, 2016 08:30 AM
RyanHostetler
Feb 6, 2015 09:30 PM
mrohitredd
Jan 19, 2014 10:23 PM
CivicVoz
Jul 6, 2012 02:43 PM
AznSaint
May 18, 2006 08:37 AM
