Help! Ep3 pulling codes without a scanner please read for story
Old Sep 27, 2018
HondaGirlep3's Avatar
HondaGirlep3 is an unknown quantity at this point
So I replaced all the plugs and cylinder 1 plug is clean and smells like fuel, 2 is slightly blackened, 3 totally black with carbon, 4 is same as one. Any ideas?
hello all, I recently replaced my camshaft on my ep3 3 weeks ago. Since then I have been unable to start the car unless I give it a bunch of gas to start & keep it running. I jumped the OBD2 port for a flashing code and eps light is flashing 22 for long and short periods of time. I can’t afford to tow it and I def can’t afford a new scanner, can someone assist? I would appreciate any insight. BTW spark plugs are all good. Thanks guys!
Old Sep 28, 2018
GolNat's Avatar
Prelude Owner
Re: Help! Ep3 pulling codes without a scanner please read for story
Did you check timing?
Old Sep 28, 2018
Colin42's Avatar
you can get obd2 scanners on amazon for like $20
Old Sep 28, 2018
BrotatoChip's Avatar
Super Moderator
Auto parts stores will also read codes for free if you can get it there.
Old Sep 28, 2018
any thing you did when you changed the camshaft is suspect. retrace. recheck
wirings, plugs, etc.
as others have said, auto parts shops would read the codes for free.
when removed, old sensors could start failing as well.
is the camshaft a type that works within the original ECU range?
all else failing, put original cam back
Old Sep 28, 2018
Hey thanks for your reply, everything appears to be perfect, I did it twice. It’s starting but won’t stay that way. Code is saying EPS 22, wtf I don’t know.
Old Sep 28, 2018
Yeah it’s perfect
Old Sep 28, 2018
It starts but doesn’t stay that way. Code showing eps 22 🤦🏻*♀️
Old Sep 28, 2018
GolNat's Avatar
Prelude Owner
Why was the camshaft replaced? Performance upgrade? What camshaft did you put in?
Drive it and get it scanned with a code reader.
Old Sep 29, 2018
Can’t drive it, ugh but thanks for reply
Old Sep 29, 2018
original cam is jacked
Old Sep 29, 2018
have a friend look at it? Preferably someone used to do mechanical/electrical jobs
2nd pair of eyes is important
CWMaguire
Oct 10, 2018 11:34 AM
03_EM2
Jun 10, 2018 12:54 PM
JesusWoreNikes
May 23, 2018 07:19 PM
kevin98208
18
Jan 4, 2017 08:10 PM
absolut_vodka98
Oct 5, 2005 01:47 PM
