Auto Trans Shifting Question
Hey guys, I was looking at a friend's car and was a little confused as to what is going on and hope you guys can help.
2002 Civic 1.7 Auto W/OD
When shifting, not even while driving just moving the shifter I seem to not have D3. I go from P-N-D no problem, after D, it goes straight to D2 and completely skips D3. No only does the D3 lights no illuminate, the shifter physically doesn't seem to have enough positions to support the D3.
problem @2 is, when shifting from D to D2, the D light will blink even after shifting back. There is/was an intermitting code for the gear selector switch but before we replace that I want to understand what is going on first.
I'm not a civic expert by any means so I hope someone can explain what is going on.
Appreciate your time.
Re: Auto Trans Shifting Question
I have a nickel that says:
Original trans took a dump. Someone replaced the trans and it was not the right one for the car. (SLXA vs BMXA, see if Google is working in your local area)
Now nobody can afford the right trans for the car.
Thanks, I will, At least it gives me a place to start. Do you know where I can find the trans code? Location?
Something had to be changed, the vehicle is showing more gears than the shifter as room to access. They either had to swap the trans, shift box/linkage or the cluster. There doesn't seem to be any physical room for that gear. I would say the linkage is out of adjustment but if that was the case I would expect to lose P or D2 not the gear in the middle.
Thanks for the input, appreciate the help.
Common repair issue is the original trans took a crap and had to be replaced.
You MIGHT be able to find a VIN tag on the trans case somewhere, then you could check what that car was.
Search this forum for 'BMXA SLXA' and see what you come up with there. Then Google search the same.
Thanks, I searched and found some threads. I'll verify before proceeding. Thanks again, appreciate your help.
Please post the code for the blinking D light in this format P####
Could be a defective transmission range switch or out of adjustment, shift cable broken or out of adjustment, or shift cable joint in transmission or body worn.
I believe it was a P1705 if I am not mistaken. My concern was the lack of range on the shifter which tells me something was changed.
The shifter shifts full range, Park is fine and the lowest gear is fine the D3 is skipped over. The shifter physically doesn't have any more room to move.
I'll take a closer look tonight and also verify the trans code.
if the linkage needed adjustment, I wouldn't expect it to miss skip a gear in the center of the shift pattern.
appreciate the advice.
You could just cobble the shifter mechanism so nobody can pull it below D and it would be fine, unless or until someone actually needed to pull it down past D.
thanks though, appreciate the information.
but there ay bean issue going in to OD but again I need to drive it to see for sure
AFAIK what I remember reading about the two trans types-- was one came in cars built in North America and the other came in cars built in Japan. One can be bolted in place of the other but The differences in the range switch, manual detents and wiring differences cause the related code(s).
Erase codes then drive it with the shifter in D, see if it sets any codes.
You already know pulling the shifter past D will cause codes so don't do that.
Does it shift wrongly or have an obvious trans problem?
A jdm transmission was put into the car. They don't have D3. I know cuz i've been looking for used transmissions online and see the jdm ones specifically saying that they don't have D3.
boriqua056
Jul 13, 2014 08:49 PM
larrysmith
Apr 8, 2012 01:18 AM
Lovesher03civic
Jul 25, 2011 10:40 PM
