question about trans issue
Old Jul 16, 2011
Lovesher03civic's Avatar
Lovesher03civic is an unknown quantity at this point
alright so i'm having a trans issue (cel p0730) it shifts fine when the car is cold, then after warming up it starts slipping, which i then lose d, d3, d2, until i lose every gear even reverse. if i turn the car off and let it sit for a while and cool down some i can start it back up and drive, with little or no slipping then it starts slipping badly again. has anyone had this prolem and fixed it or just replaced the trans? i did some research about it and it says to replace the shift solenoids, i was wondering if anyone else has done that to fix the problem or if it just continued. so should i just replace the solenoids, or pick up a used trans? i don't wanna spend $2k for a rebuild, or $4k for a jasper, too much money to put into the car with it having 165k miles. trying to stay around $1k or less if possible. i can get a used trans from lkq for $650-775. so i don't see the point in spending $200-300 for the solenoids, and shift valves unless its pretty much a sure thing to fix it. its an '03 ex at. any help is appreciated thanks
Old Jul 16, 2011
MarkoPollo's Avatar
MarkoPollo is an unknown quantity at this point
Re: p0730 cel
try changing your thread title or people are going to skip your thread all together.
Old Jul 17, 2011
Re: question about trans issue
something else i was wondering is where is the trans cooler located, external or in the radiator? i havent been under the car to look yet, so i was just wondering where to look if it is external.
Old Jul 17, 2011
its in a small corner of the radiator. just follow the cooler hoses from the trans to the radiator.is your D light flashing on the gauges or is the engine light on?
Old Jul 17, 2011
i didn't notice the d light flashing in the cluster, just the cel and the code is p0730.
Old Jul 17, 2011
code is for 'Incorrect Gear Ratio' which could be a lot of things...
Old Jul 19, 2011
yeah i checked to see what it meant but couldn't really find anything, so i was wondering if anyone had the problem, and fixed it and what it turned out being for them. however i just ordered a used trans from lkq with 75k miles so i was wondering how i can just double check to make sure they shipped me a auto trans for a 03 ex thats of course vtec and us/canadian built, is there some kind of code, marking, casting or stamp i can check?
Old Jul 19, 2011
01-05 auto trans should all work for any 01-05 year civic. so long as there is a dipstick, it should be an auto. lkq is pretty good about sending the right stuff. just make sure it looks the same as whats in the car.
Old Jul 25, 2011
MarkoPollo's Avatar
and speaking of dipstick, make sure you get the new and improved one.
werdnahall
May 17, 2015 11:37 AM
dosmastr
May 5, 2015 12:19 PM
oneheadlight
Apr 29, 2015 11:30 PM
davidpaustin
Apr 29, 2015 02:23 PM
viper775
Dec 9, 2001 10:52 PM
