03 civic bad tranny?
I have a 2003 Honda Civic with 250k miles with a auto transmission. Recently when going low speeds when I let my foot off of the accelerator my car slows down more than normal like it’s downshifting when it’s not suppose too and it makes a weird grinding noise but it only does it when I let my foot off of the petal and it only does it when the car is warmed up. Other than that it’ll shift fine and doesnt slip. Tranny fluid was changed about 10k miles ago. What could the problem be?
Re: 03 civic bad tranny?
First thought is bad transmission output bearing. Heck that is my second though too..
Its the size of a large hamburger patty and there is two of them, one on each side of the differential. If one is gone, you would could see a marked increase in drag and noises and being loaded vs unloaded would cause enough movement to make it audible or not.
Pull a sample of transmission fluid and see if you can see any shimmering in it. If it is a bad bearing, your transmission will likely “break” on you so I would not trust the car past a comfortable walking distance home.
What Slumpert said
Also, check CV boots for tears...maybe grease leaked out and is causing friction? However, if were the CV axles it should be noticeable at all speeds.
UNDERbucket
Sep 23, 2011 06:57 PM
koisser6284
Dec 26, 2009 01:27 PM
Farage
Jul 8, 2004 11:41 PM
clownprince
Apr 25, 2004 04:42 PM
