Possible 2nd Head Gasket Failure
Rep Power: 0 Possible 2nd Head Gasket Failure
Hey guys,
Replaced my head gasket at 200k after coolant resorvior was completely full and rad was low, and no heat at idle. Shop fixed the head gasket and machined the head, all that stuff.
Now I'm having the exact same issues as before. Rad cap and thermostat are all a year old and all hoses are also new.
New mechanic says I cannot replace a head gasket twice because the tolerances in the head have changed and the compression becomes to great for the piston rings to handle. Recommends new engine if HG is blown again.
Thoughts?
Thoughts?
Re: Possible 2nd Head Gasket Failure
To confirm what mechanic is saying do a dry and wet compression test. What he stated may or may not be correct but,
as far as the cylinder head there are indicators on it that cannot be milled below..so it has a finite usage in that regard.
With 200k on it probably better off with a lower mileage replacement.
Rep Power: 0 Re: Possible 2nd Head Gasket Failure
were is the coolant going ?
3 places possible ...the ground ...the oil it will look milky or ....into the cylinder and that should show up as white smoke out the exhaust
Any idea if they replaced the actual head bolts ?
Some cars use stretch bolts and they are a one time use
Tpes of headgasket failures: http://www.agcoauto.com/content/news/p2_articleid/200 and http://www.aa1car.com/library/gasket_failure.htm
Here's something you can do yourself that may correct the issue barring it's not a headgasket breach:
* Remove the reservoir and hose leading from the radiator neck to the reservoir. Blow out the hose with compressed air to ensure it's not clogged. Clean out the reservoir itself to ensure it's opening is not impeded.
OMFG will these kids ever learn ??
Blanket assumptions above are incredibly incorrect.
And there are specs to figure out if the head can be reused or not.
Received 1,449 Likes
Rep Power: 339 Re: Possible 2nd Head Gasket Failure
^ translation:
have them check against the head specs, if still within tolerance, go ahead with gasket change.
the hard part will be to know what caused the 2nd one... not milled correctly?
Not torqued correctly?
gasket brand?
gasket brand?
Rep Power: 155 Re: Possible 2nd Head Gasket Failure
How much km do you have on your engine? I think you need to get another mechanic. I had my head machined twice when I did my head gasket. The first guy did a shitty job and you can see lines on the head surface. Second shop did an amazing job and it had a mirror finish. I have about 95K on the engine since I did the head gasket around 205k. You can pull a head off a junk car if you are worry about the current one.
Nippon head gasket Honda
arp head stud
crower camshafts stage 1
valve job
polish intake/exhaust ports
replace rad
cooling fan switch
arp head stud
valve job
replace rad
cooling fan switch
Rep Power: 78 Re: Possible 2nd Head Gasket Failure
Doesn't sound like a head gasket issue to me. Nobody here uses the coolant combustion gas test kit? IE the little vial that changes color. Is that too easy?
Received 1,131 Likes
Rep Power: 192 Re: Possible 2nd Head Gasket Failure
Honda engines fail a little differently, most common tests don't show the failure.
this test works everytime
wwhitby
11-17-2018 11:40 AM
Slicer1989
21
03-20-2018 05:21 PM
pt00323i
09-08-2011 01:56 PM
