Leaking Oil-Defective Ignition Coil??
Old Dec 17, 2017
Kennykenny's Avatar
Kennykenny is an unknown quantity at this point
I am finding oil on the 4th spark plug(only the 4th plug) on my 2005 Honda Civic. Upon taking the mentioned spark plug out, I noticed that the rubber end of the ignition coil had a couple of splits in it. Just wondering, could the splits be causing oil to enter onto the plug? Can the rubber ends be replaced and/or necessary to purchase a new coil? If need to replace the coil, replace all 4 or just the one as needed?
ID:	111871   Click image for larger version
ID:	111872   Click image for larger version
ID:	111873   Click image for larger version
Old Dec 17, 2017
Re: Leaking Oil-Defective Ignition Coil??
Impossible.
Closely inspect the ring seal in the valve cover--- that fits over the plug tube and I bet the edge (lip) of the seal got caught over the top of the tube instead of around it. You MIGHT be able to push the seal into correct place if you loosen the V/C bolts and lift it up slightly and work the seal with a fingernail or small screwdriver. If you tear the rubber of the seal it's toast, needs the v/c gasket set replaced.
Will need to buy one ignition coil to fix the boot problem. Make sure to clean the oil out of the hole and the plug is clean.
Old Dec 18, 2017
Kennykenny's Avatar
Originally Posted by ezone
Impossible.
Do you think that the oil could be from a possible leaking valve cover gasket?
Old Dec 18, 2017
The seal on your leaker will probably look much like the one in this image (if this pic works):
[img][/img]
From this thread: https://www.civicforums.com/forums/36-mechanical-problems-vehicle-issues-fix-forum/354349-oil-leaks-another-issue.html
The four tube seals should be included in a valve cover gasket set.
john1976
Oct 11, 2015 06:08 PM
bsoto
19
Oct 26, 2014 07:00 PM
Lordsin
Apr 22, 2014 07:36 PM
satown210
Mar 2, 2011 05:46 AM
icebergslim
Engine Swaps
Sep 13, 2003 05:50 PM
